Originally Posted By: Garak
Originally Posted By: fdcg27
I'll put on my fireproof underwear and note that Shell specifically recommends that Rotella oils not be used in any vehicle with a catalytic converter.
Your 95 BMW probably called for a similar oil spec to this 94 LC. The Defy you're running has similar phosphorous numbers to the Rotella. So, what's the issue? Ask Shell what they think of using Defy in vehicles equipped with catalytic converters. I dare you.
If an LC with 411,000 miles is consuming some oil and has failed cats, I wouldn't be surprised. I also wouldn't be blaming the oil.
Hi Garak,
You must have felt strongly about this since you posted it twice.
The BMW had API SG recommended for it in really thick grades when new. I have no idea what sort of ZDDP content was typical of the time.
For all I know, the BMW does have a failing cat.
It's an OBD 1 car, so there is no O2 sensor downstream of the cat, so there are no catalyst efficiency codes.
WRT what SOPUS would say about using Defy, I think that we both already know the answer to that.
I've used 10W-40s of various brands in various catalyst applications, with their allowable higher ZDDP levels compared to thinner grades and I've also used Rotella 5W-40 in a few.
No problems ever noted, but none of the engines I used these oils in had consumption anywhere near that of this Land Crusher.
Shell really does recommend that Rotella oils not be used in catalyst equipped vehicles. They confirmed this to the owner of the wagon in question.
I wonder why that is?
Is it just a matter of the ZDDP levels, or is there something more?
I'd love to hear a full explanation from Shell, not that we'll ever get one.
I'd also like to know why the oil is dual rated if it shouldn't be used in vehicles with catalytic converters, which have been nearly universal in cars and light trucks for the past thirty five years or so.
