This is a revised UOA on my 2006 Honda Accord. I noticed the additive levels in the original seemed off for the Honda Conoco Phillips oil, so I mentioned it to Blackstone and the happily re-sampled it for me. The tin dropped from 3 ppm to 0 ppm. All other wear metals stayed the same, and the additives dropped down into the range I expected them to be for the Honda blend. I am happy with the "wear" numbers, they are the lowest I have seen them. When viewing other Honda 0w20 UOA's I have always seen high AL and sometimes high IRON, not the case here thankfully. Not sure why there is a trace of fuel this time. I did even shorter trips in the winter and had no noticeable fuel present. Anyway, here is the report. Oh, and a Fram Ultra was used.
