You got room for longer and/or wider? I would never run a small wix - the base-end bypass assembly(very good idea) takes up too much room displacing media area (not so good)If You cant find a wix run a Delco non-ecore - will most likely give you ~30% more filter media. Your dimensions:
Part Number: 57060
UPC Number: 765809570603
Principal Application: Various Buick, Chevrolet, GM, Hummer, Saturn, Saab, Dodge, Chrysler, Jeep (07-12)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.450
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 12
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=6/20
Max Flow Rate: 10-12 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.758 2.420 0.270
