So I have a little bit of DIY plumbing knowledge (emphasis on little bit). I noticed what appeared to be a leak in our shower at home. In the process of rounding up what I thought to be the usual possible suspects I attempted to pull the shower stems in order to check for signs of wear. The cold water stem and diverter stem are pretty well stuck in place, and I've had 0 success breaking them free (hot water I got without issue). Anyone have any tricks/recommendations as to how to go about this? The wall is an insert rather than tiles, so working space is fairly limited.
