To summarize Bestline is a dino/syn blend with solvent (kerosine), teflon (Flourocarbon resin) and extreme pressure (Calcium Sulfonates) additives.
Also notice the flash point is only 83C (181F) while API certified motor oils are well over 200C (392F). Flash point is a temperature at which product evaporates to form an ignitable mixture. That's really troublesome since engine normal operating temperature is just over 100C or so. I guess that's why in the demo video they had to drain the motor oil out after it was treated with the Bestline product, - to make sure engine doesn't blow up during the run in hot Florida weather.
That's alright Bestline, I'll stick with adding a cup of Head & Shoulders routine during my oil changes. Just kidding...
