Originally Posted By: dave5358
Originally Posted By: widman
You can download the Charter. It contains several interesting things, but most amazingly, fuel that meets it (other than the top tier ones) can still clog injectors 10% in 10,000 miles, and allow carbon deposits up to certain limits. Also minimum octane of 91 RON (about 87 AKI).
Why is this amazing? They are simply setting a standard. If all fuels clog injectors to some extent, then why not specify an acceptable limit on clogging?
Of course down here our gasoline is only 85 RON, so you have to add your own detergents.
I'm not sure RON has anything to do with detergency or vice versa.
I wasn't saying it does, but that in some places the gas doesn't even meet the octane standard, much less anything else.
