The B2300 idled badly at 1000RPM and after about 10 miles threw a P0108 code. (MAP high) Prior to buying a new sensor, I did a visual and noticed about 1/4" of wire missing from the connector to the sensor. Thanks Ford for designing a electrical system so attractive to small rodents as this is my 2nd chewing repair....
The wire has been chewed off right up to the connector (< .050 length of wire left) so I need to figure out how to remove the wire from the connector. Seems like there is some sort of pin removal tool. I'm not looking for a tool to separate the connector from the sensor, but a tool to seat a new wire into the connector. The broken wire seem to go into a hole about 1/16" in diameter that has a blue rubbery seal circling the wire. Can someone point me to a generic tool to do this wire replacement and how it works. I looked on the web and there seems to be a bunch of tools that don't look too similar and I can't see how they work.
Thanks.
edit:
http://www.amazon.com/Lisle-57780-Termin...8RKV41F1B19JMTW
Is this it; how does this work?
Thanks.
edit:
