only does it after the vehicle has sat for a bit and evens out after a few moments
when i start up it runs rough kinda feels like a misfire in the past it would occasionally do it but a little tap of the gas pedal fixed it... now the tap of the gas pedal just makes it run rough at a higher rpm until it evens out
if it sits for a few minutes after running it starts up fine... but an hour or more it will run rough when i start it again
