Overall the paint on my Accord is in decent shape. However, on the rear driver side door the upper portion of the door (right below the window above the character line) looks to be "fading", or "hazy". A good way to describe it is when you look at your reflection in the paint, you can see yourself pretty clear, but when you look at yourself over this section, its hazier. So, the question is, would it help, or hurt to use a polish of sorts (I would be using ZAINO swirl remover by hand). Would this help clear it out? Or would it take away more clear and make the issue worse? So far I have been keeping the car waxed on a regular basis, and using spray wax every other wash. Hoping this will help. Your input is appreciated!
