Okay so at my previous oil change (3months ago) for my Toyota the oil filter was hand tight (or 2/3 of a turn after it meets the mounting surface etc) and there would be very minor leaks coming from the filter. I had it as handtight as possible and this kept on happening after removing and refitting the filter multiple times.
I decided to use my filter removal wrench and tighten the filter.Looks exactly like this:
Hooray! the leaks stopped.
But now the problem is that the "prongs" on the filter wrench have caused slight indentations on the filter. The filter has been fine ever since and have not had any problems with oil pressure or leaks etc. should I change it before my next oil change? At my current mileage I should be getting oil+filter done in around 2 months time so should I just leave it until then...
