Originally Posted By: gathermewool
Change it IAW the manual. Unless someone can provide any logical reason for changing it more frequently, stick to what the manual States. If you change it at the manufacturer-recommended interval you'll probably still be better than the majority of people who don't change it ever.
Originally Posted By: Kuato
Originally Posted By: Ramblejam
105,000 miles or seven years.
https://owners.nissanusa.com/content/techpub/common/2012/2012-nissan-service-maintenance-guide.pdf
So to make it easy, simply drain and refill the radiator every 4 years and never worry.
How did you come to this conclusion from that link?
I never said I came to the conclusion from the link. You did.
However, Nissan says 7 years or 105k. 4 years is roughly 1/2 the interval, and if my research is correct, the radiator is more than 1/2 the capacity of the system if you include the expansion tank. Refreshing the additives at 1/2 the interval will keep the coolant operating well, much like when you have an oil burner and don't do an oil change since you are adding a quart of oil every 1k.
My experience also tells me this will work great. During the 80s and 90s I drove cars that all used the green coolant, some were almost 20 years old and over 150k. On all these cars, the radiator was drained and refilled at a 2-3 year interval. Never once did I have a corrosion or scaling problem, nor did I have to do any work on heater cores or radiators due to leakage.
Originally Posted By: Silverado12
This has worked for me for the past 35+ years: On a new car, drain and refill after the first 3 years, then drain and refill every 2 after that.
Exactly; although you're a bit more aggressive than I am.
