This is the oil change after my break-in oil change at 1800 miles. I have a short commute (5mi) but also take occasional long trips. I drive pretty easy most of the time and I think the oil analysis shows that. I'm so happy there is no significant fuel dilution and the TBN will absolutely take the MGMO to 7500 miles. Here is Blackstone's analysis
"DOMINIC: Copper and silicon are reading high in this first sample from your Mazda, but these readings are normal for a new engine such as this. In fact, we would've been more surprised if they hadn't been there. New engines produce excess copper (from brass/bronze parts), along with other wear metals, and silicon is from harmless sealers. A lot of this washed out in your first oil change, and things should improve more next time. Averages are based on ~6,100 miles of oil use, but your strong TBN of 4.4 says you can go longer. Try 7,500 miles and check back. Nice!"
Code:
Oil Brand Mazda
Oil Type OEM with Moly
Oil Weight 0W-20 SN
Miles on Oil 5800
Miles on Car 7600
Sample Date 7/23/2014
Aluminum 2
Chromium 0
Iron 18
Copper 34
Lead 0
Tin 1
Molybdenum 732
Nickel 1
Manganese 1
Silver 0
Titanium 0
Potassium 5
Boron 231
Silicon 25
Sodium 6
Calcium 2190
Magnesium 12
Phosphorus 754
Zinc 884
Barium 3
cSt Viscosity @ 100C 6.92
Flashpoint 400
Fuel
Antifreeze 0
Water 0
Insolubles 0.2
TBN 4.4
Code:
Oil Brand Mazda
Oil Weight 0W-20 SN
Miles on Oil 5800
Miles on Car 7600
Aluminum 2
Chromium 0
Iron 18
Copper 34
Lead 0
Tin 1
Molybdenum 732
Nickel 1
Manganese 1
Silver 0
Titanium 0
Potassium 5
Boron 231
Silicon 25
Sodium 6
Calcium 2190
Magnesium 12
Phosphorus 754
Zinc 884
Barium 3
Flashpoint 400
Fuel
Antifreeze 0
Water 0
Insolubles 0.2
TBN 4.4
