If it's the 1.8L, they suffer from stuck oil control rings. My 94 has the same issue (I however make sure there IS oil in it at all times
If ever there was a test case for Kreen, here it is! You know you want to Turk!
Make sure she checks the oil at every fuel fillup or every 500 miles. I've read that when these engines get 1 quart or more low, oil starvation can occur from sloshing in the sump.
