Originally Posted By: GaleHawkins
Any use in WWII would at best been experimental at best.
Thats almost a certainty. I mean its qualities as a dry lube were well established by that time and they had been using it in the formulation of armor plate since WWI.
I don't think anyone is disputing the lubrication properties of MoS2 or its effectiveness as a lubricant.
I prefer Moly fortified greases and special dry lubes for a host of things, nothing works better (except maybe WS2 but where are you getting that?), in CV joints its mandatory for long life.
In my own situation and that of many owners that use their vehicles seasonally there are questions that remain.
The main question is.. Even if does stay in suspension in new oil is it attracted to dissolved solids that fall out of suspension over a longer period taking the MoS2 with it?
This is a real problem and we have all seen it, change the oil, pour the used oil into a gallon jug only to see a few months later a lot of the deposits that were in the oil are now on the bottom of the jug.
The longer it sits the more falls out. I cant see this being an issue in a daily driver that is in use 365 but it is certainly a real concern for some of us.
For that reason i don't use anything anymore in the oil as i don't own a daily driver per se. They are either summer or winter vehicles and sit off season.
Is MoS2 snake oil? Definitely not. Does it provide any real benefit in modern engine oil? IMHO no but to each his own, it is harmless so for those that do use it no harm no foul.
I definitely wouldn't recommend it for seasonal vehicles.
