Originally Posted By: Cardenio327
OP, you are in Mexico, right?
Originally Posted By: Dustained
Nissan GA16DE
Call around to Nissan dealerships, that engine is available brand new as a crate engine for $19000 pesos. There is no reason whatsoever to rebuild a GA16DE unless you want to do it for fun.
I've worked in the auto repair industry in Mexico for 5 years. I would never have an engine rebuilt here for the following reasons; lack of parts availability, lack of cleanliness in shop practices, lack of precision measuring and milling equipment, lack of knowledge, and dishonesty caused by the pressure of competing with dishonest competitores.
Recent case with one of my customers: Late nineties Suburban 5.7 Vortec, came to me for a second opinion, misfire and clatter on cylinder #1. After advising him it isn't my area of expertise, I did some basic diagnostics for free. I opined a stuck valve, about $15000 for a complete valve job. On teardown, the crooked mechanic found a broken connecting rod, and went ahead and rebuilt the engine anyway because it hadn't damaged the block much! The customer brought it to me afterwards for my opinion, it would barely run. The crooked mechanic wasn't even able to get the cam timing right when he put it back together!
Yes, the engine is available at Nissan dealerships at 19,000 Mexican pesos, about 1400 USD, but it's not the GA16DE, it's the GA16DNE, the Mexican version without the ECCS intake manifold and without the variable valve timing... and 10 less HP.
My engine:
Mexican version which is the one they sell here:
The block is the same, but the valve train is totally different as the Mexican version lacks the longer camshaft where the hydraulic variable valve timing thingy resides.
Yes, I live on a plateau, the Yucatan peninsula, this thing is as flat as a dinner table for hundreds of miles. I drive in OD, and once the car reaches the desired speed on the highway, I don't need to move my foot at all.
