Originally Posted By: Paddy1337
Originally Posted By: phil240
Yes it is a single turbo and if you read through my post this is not my daily at all.
gotta say, you are coming off a little bit like a **** in some of your posts to people who are just trying to help you. BUT, this is the internet, and things aren't always how they seem.
Anyway. My #1 recommendation for picking the oil weight is talk to your engine builder. Hands down he, and no one else, will have that answer as to what is best. He knows the bearing clearances he's speccing, and he also has likely built many engines in the past and seen how they do with certain weights vs bearing clearances. The second consideration might be to look to your turbo manufacturer for their recommendation, some of them have some strong opinions on oil.
I have a pretty loose motor, similar in concept to your SR20. It's a stroked 4G63 in my Evo (technically it's a 4G64 but who cares right?). Now, I've personally never had a sleeved motor, so MAYBE that has an effect I don't know about, but I run AMSoil ZRod 20W-50. Once I ran Brad Penn 20w-50 due to availability, and it didn't break, lol. My oil pressure is on the high side though, so I've been considering ways to reduce that slightly (mechanically).
The motor is currently 3 years old, with 2 seasons of racing. The racing is LOTS and lots of drag racing, with some autox mixed in, and street driving mixed in. Made 600whp/540tq on a mustang dyno, and maxes at 41psi on kill mode. It's also been on E85 for all of 2013 (was C-16 for 2012).
I'm actually about to do my first oil analysis very soon, because I'm thinking it's time to refresh the motor. I would just rebuild it without thought, but for 2014 I've also bought and am building a rally car, and that is taking my spare funds. So I'll be looking to oil analysis to help me decide what all I should do to the motor for next year.
Last but not least, if you're still reading, I do not actually run the oil for very long on average. for all of 2012 religiously and less so in 2013, we would change all my fluids after every track day. but at 7-8qts of ZRod, plus trans and diffs, that was getting stupid expensive. I'm going to also look to oil analysis to help me decide my plans for oil in the future. Either extending my change intervals (not my top pick), or using a less expensive oil at the same way too often change intervals (I'm thinking Brad Penn). My shop loves AMSoil. We've had amazing results with it over the years. But, I think that likely most of the benefits AMSoil has over some other oils I could be using, are all benefits that don't matter to me, like extended drain intervals.
**Hope some of this is helpful**
-Tim
Thanks for the input on the matter, I don't mean to come off as a **** but 1. people don't actually read what you post before offering up advice or criticism and 2. sometimes people don't have a problem spending money on a better product it doesn't always have to be the best bang for the buck.
Now that being said yes this is a looser clearance motor it's still at the builder and i'm awaiting return so i don't have it back yet. It wasn't a dire matter to bug them about oil specs yet as I'll get all the info when it's done. My skepticism is that it's a looser clearance within factory spec engine so that will probably give me a few options to choose from.
I do know lots of people run 20w-50 in their evo's, I personally run 5/10w-40 in my wife's MR but it's pretty mild and all but stock. I didn't really mean to ignore help about what oil to use in my car but I like that if advice is offered there be more info backed then general consensous is, after all I do read up on sr20 stuff just haven't much into the fully built semi street driven side as most people don't have or want to spend that kind of money.
I have friends that rave about amsoil products ones actually a dealer, I personally never used it so i have no info or experience with it. I was actually a Royal Purple fan when others used to bad mouth it with no proof of there claims and now i am looking for one of the top companies with a 5/10w-40 and 10/15/20w-50 weights so i can run in plenty of different setups with the use of one brand.
As with your track habits of changing fluids after every event i sorta wanted to not have to do that if I could, I am planning on short oci around 2-3k and 60-70% will be hard street driving so i wanted something i can leave in a little longer.
I am looking forward to using UOA to help in oil choice and longevity in my situation.
Used a lot of I's in here please ignore my english, drove myself nuts rereading it.
