Originally Posted By: Trav
PEA based cleaners work very well in these types of injectors, the sooner you begin using them the better, they are hard to clean once the stuff as built up, its better to prevent it as much as possible.
Using top tier fuel may or may not be of benefit, some companies only put decent amounts of detergents in the high octane fuels, the lower octanes may only meet the minimum.
I like Redline SI-1, it is made for continuous use, a few ounces per tank will go a long way in keeping them in good shape.
Whether or not PEA helps the back of the intake valves is still being debated.
Thanks Trav! This is what I was attempting to ask you on a previous thread, whether or not you thought these products were worth using as a form of prevention.
