Why would the cable modem be 192.168.1.1?
it's a modem? would it not have the public IP address that was assigned to the end user by the ISP's server?
the modem should be
http://192.168.100.1/
or similar for the status page
The router is separating the network ..
the external part of the router is going to have the ip address of the cable modem which is assigned by the ISP and wouldnt be a private address, and the internal part should be whatever is setup in the router
typically 192.168.1.1 or similar.
looking at the manual its just a regular 1 port docsis 3 cable modem? unless I'm missing something.
I dont see that its a gateway combo device at all.
Originally Posted By: mattwithcats
IP address conflict, both the Cable modem and router have IP addresses of 192.168.1.1
Unplug the Wifi router from cable modem. Use a network cable to connect your computer to one of the downlink ports
(not the single uplink where the Cable modem plugs in, the four ports for computer hookups).
Now try 192.168.1.1 You should be able to log in. Change the IP address of the router to 192.168.5.1.
How much computer knowledge do you have?
maybe the cox technican reset your router?
have you done any troubleshooting plugged in or over wireless?
You can also plug computer directly into the cable modem with a ethernet cable.
then restart the modem and computer.
if you have internet its not a modem problem.
Also you can
Try unplugging the cable modem from the router and seeing if you can connect to the router from the computer (with the computer connected to the router with an ethernet cord)
you say
Quote:
My internet service provider, Cox, recently installed a new cable modem (dpc/epc 3010). Since then, I have been unable to go into wifit router login or even reinstall my router’s software (It gets to the point that it checks to see if I am hooked up and I can’t get pass that).
You typically dont have to install any software, you can just goto the router's webpage from a browser.
What Ip does your computer have? What tcp/ip settings?
Did you try resetting the router with the reset procedure? Usually holding down a button on the back of the router.
