Originally Posted By: MNL
I'm planning to use a Napa Platinum when I do my oil change this weekend. It's a very solid filter and similar, if not the same as the WIX XP oil filter. Thick canister, full synthetic media and silicone ADBV. Some members here will steer you away from it as the Platinum's efficiency is 99% at 35 microns (80% at 20?) and will recommend the Napa Gold (or Fram Ultra)
The Wix XP/Napa Plat beta ratios show a 50% @ 20 micron rating, but not much worse than the Honda OEM filters, which i believe are
If you take the efficiency out of the picture, the filter looks great upon every dissection and construction appears top notch.
I would be one of those to steer you into the Fram Ultra which is 99%+ @ 20 microns, and 80% @ 5 microns, the best posted figures of any company i have seen. Amsoil comes close with 98.7% @ 20 microns, but no 5 micron figure posted and price and availability are an issue.
