Originally Posted By: rslifkin
Driving style is definitely part of my issue with FWD in the snow. FWD tends to understeer badly under any throttle, and the only times I've had an issue with snap oversteer not induced by an ice patch have been in FWD cars (light rear end comes around FAST once provoked).
RWD, if it's set up right (especially in a setup with a lot of caster up front) will throw the rear end back in line with just a quick flick of the wheel, even with the vehicle almost totally sideways. The key is knowing how to time steering and throttle to get the rear end to stick on the recovery.
I also like being able to steer with the throttle, so when I hit a slick spot in a tight turn and it starts to push, it's nice to be able to blip the throttle, step the tail out a little and get the front end to hook back up (and rotate the vehicle through the turn).
Just how aggressively are you driving? Or are you talking about track driving?
