http://lubematch.shell.co.uk/us/en_US/equipment/suburban_k1500_5_7_4wd_suburban_EFt8Pk0ZD
Stick with the recommended oil bud.
I wouldn't mix oils, you only end up unbalancing the additive package which will lower the oils performance.
Ideally you need to get the actual oil pressure data from Chevrolet. Can you/do you have an oil pressure gauge that you can screw into the oil pressure switch/sensor hole and check to see what your actual oil pressure is?
