I am looking to replace my 18" oem wheels on my 4.6l Genesis with 18" wheels from a Genesis Coupe but doing so means moving from a wheel with 39mm offset to a staggered wheel setup where two wheels would have a 30mm offset and two would have a 33mm offset. Since the tires I am mounting will be winter tires in the oem 235/50-18 size I don't expect I will have issues with fender clearance.
What are the risks of using a wheel with a different offset? Fwiw, all of the wheels recommender by the tirerack appear to be wheels with a 35mm or 40mm offste. Does it matter that much?
