Since AMSOIL published their own comparo of various ASTM tests, some have inevitably noticed ranges of variability in the results of various tested blends.
The issue of DI deposits has gained prominence in recent history, with owners concerned about ways to prevent or minimize the issue. Logically, since intake buildup on DI engines are referred to as "deposits", it is then logical to turn to a deposit test. This is perfectly logical. However, logic (by m atching concepts using the same word of the english language) is not enough. This is where the TEOST camp falls short.
A deposit test is not a deposit test is not a deposit test.
TEOST 33C procedure highlight:
This test is specifically modeled to predict turbine bearing deposits.
Full-composition motor oil is pumped over a heating rod in a laminar fashion, which represents a turbine shaft. The full-composition oil is intentionally reacted with oxygen and a catalyst.
A note regarding the higher TEOST deposit on the high-moly oils in the AMSOIL test:
http://papers.sae.org/2008-01-2480/
DI Intake valve:
Highly turbulent environment in which the valve is mainly 'dry'. When they do, some components of the motor oil encounter the valve (light fractions, polymers, P additives) at higher/inproportional ratios vs the full-compositional, laminar, wet flow over the heated-test rod in 33C.
For example, since it is known that organic moly has a markedly negative effect on the 33C, at least two questions arise; how much of a problem is MoDTC (& other additives that may work in a similar way) for dry DI intake valves? How likely are those components to arrive at, and deposit onto the valves?
DI Intake valve:
