Looking for help from anyone here familiar with a 2000 MK4 / A4 VW Jetta's manual (not Climatronic) AC system:
In the last week, my AC would intermittently stop working. Sometimes it would work, sometimes not, either from start or while idle. When it works, it is cold and it does not turn off as long as I have the engine on. When I shut down the engine and turn it on again, sometimes it will work, sometimes not.
I found the following while troubleshooting:
1. With ignition on, fan speed to lowest, AC button on, both cooling fans are not turning. With engine on, and fan speed on, and AC button on, the cooling fans and compressor are still not turning.
2. I checked both low & high pressure of my AC with my manifold gauge with engine off results in 100 psi static pressure. I could only check static pressure because the AC compressor wont turn on.
3. There is a voltage of 3.5v from the AC compressor wiring harness - normal voltage is 9 to 9.5 though.
Given these findings, I've narrowed down the faults to three parts:
a. the high pressure sensor which sends a signal to the Fan Control Module to stop both fans and AC compressor if there is too much refrigerant pressure or not enough pressure in the system is not sending a signal,
b. the Fan Control Module which receives signal from the pressure sensor to power or cut off power to both cooling fans and the compressor is receiving the signal but can't send power to those parts,
c. the temperature control dial in the central stack which would basically not turn the AC compressor on if it's stuck in heater mode - though no heat is coming out of the vents.
Any ideas? I just don't want to throw all three parts at this problem if I can eliminate them one by one first.
