VW OIL Conversation
Reno, NV
Here is a "Chat" I just had on line with the "VW Chat:
Jennifer W said:
Hello Jack Atherton. My name is Jennifer W. How can I help you?
Jack Atherton said:
I have a 2014 Passat Wolfsburg, can I use 0-40 Castrol Edge motor oil (It has the VW 502.00 Certification)?
Jennifer W said:
I hope you're enjoying your Passat Wolfsburg! I will be happy to check into that for you; it will be just one moment!
Jennifer W said:
I appreciate your patience, Jack. Castrol Edge 0-40 is not on our approved oil list, so we don't recommend it.
Jennifer W said:
I can email you a copy of the list if you'd like.
Jack Atherton said:
Please do. However, why do you bother to have a 502.00 certification if you don't honor it?
Jack Atherton said:
My email is: [email protected]
Jennifer W said:
Thanks! It's possible the list was updated at a different time than the oil was certified. I apologize I don't have more information.
Jack Atherton said:
My question remains, if an oil is certified for the 502.00 is it ok to use?
Jennifer W said:
For us to recommend it, it needs to also be 5W-30 or 5W-40 synthetic oil. If it's not on our approved oil list, we can't recommend it, even with the 502 00 standard.
Jack Atherton said:
Then what is the purpose of having a standard (Of your own devising) if you don't honor it? There is no oil like you describe available at the car parts stores in Reno.
Jennifer W said:
I apologize. I will be happy to send you our list of approved oils to help find one that will work for your vehicle.
Jack Atherton said:
In the VW owners manual that came with the car it says that if the recommended weight of oil is not available in your area you can use any 502.00 oil that is of a weight suitable for your climate. What could be more suitable than 0-40. I shouldn't have this much trouble buying a quart of oil!
Jennifer W said:
I'm sorry for this experience. I am going by the resources we have available here and don't want to give you incorrect information.
Jack Atherton said:
Could you refer me to someone with knowledge!
Jennifer W said:
I checked with a product specialist as well, who also said it isn't recommended.
Jack Atherton said:
I don't care if it is recommended. I want to know if it will be ok for the warranty.
Jennifer W said:
If improper oil use causes damage, then that repair won't be covered under warranty.
So, what is on that list that she sent you?
FYI, Edge 0w-40 is on the VW approved oil list, but maybe the US has its own list (not sure why it would)...
http://www.my-gti.com/2534
The oil in question is on the list. I believe it is not the correct weight (5-40). The 0-40 doesn't please their Teutonic palate I guess.
502 00 - Gasoline engines
505 00 - Diesel engines
504 00 / 507 00 - Gasoline and Diesel engines
Brand Name SAE - Spec. VW - Standard
ACT Voltronic Motor Oil SAE 5W-40 50200/50500
AD Parts AD SDI SAE 5W-40 50500/50501
Adamol Adamol Multitop PDI SAE 5W-40 50200/50500/50501
Addinol Addinol Eco Light SAE 5W-40 50200/50500
Addinol Addinol Extra light MV 038 SAE 0W-30 50200/50500
Addinol Addinol Extra Power MV 0538 LE SAE 5W-30 50200/50500
Addinol Addinol Giga light MV 0530 LL SAE 5W-30 50400/50700
Addinol Addinol Light MV 0546 PD SAE 5W-40 50500/50501
Addinol Addinol Mega Star SAE 5W-30 50400/50700
Addinol Addinol Semi synth MV 1047 SAE 10W-40 50500/50501
Addinol Addinol Super light MV 0546 SAE 5W-40 50200/50500
Addinol High Star SAE 5W-40 50200/50500
Addinol Mega Light MV0539 LE SAE 5W-30 50400/50700
Adnoc Adnoc Image SAE 5W-30 50200/50500
Adnoc Adnoc Image SAE 5W-40 50200/50500
Adnoc Adnoc Pearl SAE 5W-40 50500/50501
Agip Agip 7004 SAE 5W-40 50200/50500/50501
Agip Agip 7008 SAE 5W-30 50400/50700
Agip Agip Extra HTS SAE 5W-40 50200/50500
Agip Agip Formula FUTURE SAE 5W-30 50400/50700
Agip Agip Sy nthetic PC SAE 5W-40 50200/50500
Agip IP SINTIAX 505 EXCLUSIV SAE 5W-40 50200/50500/50501
Agip Sint Evolution SAE 5W-40 50200/50500
Agip Sint Turbo Diesel Evolution SAE 5W-40 50200/50500
Agip Tecsint SAE 5W-30 50200/50500
Agip Tecsint SL SAE 5W-40 50200/50500
Aral Aral HighTronic SAE 5W-40 50200/50500
Aral Aral P 426 SAE 0W-30 50200/50500
Aral Aral SuperSynth SAE 0W-40 50200/50500
Aral Aral SuperTronic SAE 0W-40 50200/50500
Aral Aral SuperTronic G SAE 0W-30 50200/50500
Aral Aral SuperTronic Longlife III SAE 5W-30 50400/50700
Aral Aral Tronic 431 SAE 5W-40 50200/50500/50501
Armorine Couguar SAE 5W-40 50200/50500/50501
Astris Astris Matro L-3 SAE 5W-30 50400/50700
Auto-Teile-Ring Cartechnic Motorenöl SAE 5W-40 50200/50500
Auto-Teile-Ring Cartechnic Motorenöl Longlife III SAE 5W-30 50400/50700
Auto-Teile-Ring Cartechnic Motorenöl MS SAE 5W-30 50200/50500
Avia Avia Synth SAE 5W-40 50200/50500
Avia Avia Synth Longlife III SAE 5W-30 50400/50700
Beijing Tongy i Petroleum Xin Gai Nian SAE 5W-40 50200/50500
Blu Lubricants Inc Blu Synthetic SAE 5W-30 50200/50500/50501
BP BP EuroSpirit SAE 5W-40 50200/50500
BP BP Prof essional EURO Plus SAE 5W-40 50200/50500
BP BP Visco 5000 SAE 5W-40 50200/50500
BP BP Visco 5000 C SAE 5W-40 50200/50500/50501
BP BP Visco 7000 SAE 0W-40 50200/50500
BP BP Visco 7000 Longlife III SAE 5W-30 50400/50700
BP BP Visco 7000 Sport SAE 5W-40 50200/50500
BP BP Visco 7000 Turbo Diesel SAE 0W-40 50200/50500
BP BP Visco 7000 Turbo Diesel Sport SAE 5W-40 50200/50500
BP BP Visco 7000M SAE 0W-30 50200/50500
BP BP Visco Special V SAE 5W-40 50000/50500/50501
BP BP Visco Special V SAE 5W-40 50200/50500/50501
BP Meister-Öl Leichtlauf -Motorenöl SAE 10W-40 50200/50500
BP Meister-Öl Leichtlauf -Motorenöl SAE 5W-40 50200/50500
Bucher AG MOTOREX PROFILE V-XL SAE 5W/40 SAE 5W-40 50200/50500/50501
Bucher AG MOTOREX Select LA-X SAE 5W-30 50200/50500/50501
Bucher AG MOTOREX Select SP-X SAE 10W/40 SAE 10W-40 50200/50500
Bucher AG MOTOREX Select SP-X SAE 5W/30 SAE 5W-30 50200/50500
Caltex Caltex Havoline Ultra V SAE 5W-30 50400/50700
Carat ad-Diesel PD Oil SAE 5W-40 50200/50500/50501
Carat ad-High Tech Longlife III SAE 5W-30 50400/50700
Carat ad-Synt Oil SAE 5W-40 50200/50500
Cartechnic CARTECHNIC Motorenöl Pumpe- SAE 5W-40 50000/50500/50501
Castrol Adamol Multitop PDI SAE 5W-40 50200/50500/50501
VW Oil Standards
Castrol Castrol Edge SAE 0W-30 50200/50500
Castrol Castrol Edge SAE 0W-40 50200/50500
Castrol Castrol Edge SAE 5W-40 50200/50500
Castrol Castrol Edge SAE 5W-30 50400/50700
Castrol Castrol Edge Formula RS SAE 0W-40 50200/50500
Castrol Castrol Edge Sport SAE 0W-30 50200/50500
Castrol Castrol Edge Turbo Diesel SAE 5W-40 50200/50500/50501
Castrol Castrol Formula SLX SAE 0W-30 50200/50500
Castrol Castrol Formula SLX Long Tec Turbo Diesel SAE 0W-30 50200/50500
Castrol Castrol Formula SLX Professional Powerflow SAE 0W-30 50200/50500
Castrol Castrol GTX 9 Magnatec SAE 5W-30 50200/50500
Castrol Castrol GTX Magnatec SAE 5W-30 50200/50500/50501
Castrol Castrol GTX Magnatec C3 SAE 5W-30 50200/50500/50501
Castrol Castrol Magnatec C3 SAE 5W-30 50200/50500
Castrol Castrol Magnatec C3 SAE 5W-40 50200/50500
Castrol Castrol Magnatec C3 SAE 5W-30 50200/50500/50501
Castrol Castrol Magnatec Diesel B4 SAE 5W-40 50200/50500
Castrol Castrol Magnatec Diesel B4 SAE 5W-40 50200/50500/50501
Castrol Castrol Magnatec Diesel C3 SAE 5W-40 50200/50500
Castrol Castrol Magnatec Professional C3 SAE 5W-30 50200/50500
Castrol Castrol Magnatec Professional C3 SAE 5W-40 50200/50500
Castrol Castrol Magnatec Professional C3 SAE 5W-30 50200/50500/50501
Castrol Castrol Magnatec Professional SAE 5W-30 50200/50500/50501
Castrol Castrol Magnatec Professional SAE 5W-40 50200/50500/50501
Castrol Castrol SLX SAE 0W-30 50200/50500
Castrol Castrol SLX 505 01 SAE 5W-40 50200/50500/50501
Castrol Castrol SLX Longtec SAE 0W-30 50200/50500
Castrol Castrol SLX Professional SAE 5W-30 50200/50500
Castrol Castrol SLX Professional SAE 5W-40 50200/50500
Castrol Castrol SLX Professional 505 01 SAE 5W-40 50200/50500/50501
Castrol Castrol SLX Professional B4 SAE 5W-30 50200/50500/50501
Castrol Castrol SLX Professional C3 SAE 5W-30 50200/50500
Castrol Castrol SLX Professional Diesel SAE 5W-30 50200/50500
Castrol Castrol SLX Professional LL03 SAE 5W-30 50400/50700
Castrol Castrol SLX Professional Longlife III SAE 5W-30 50400/50700
Castrol Castrol SLX Professional Longtec SAE 0W-30 50200/50500
Castrol Castrol SLX Professional Longtec SAE 0W-40 50200/50500
Castrol Castrol SLX Professional OE SAE 5W-30 50200/50500/50501
Castrol Castrol SLX Professional Powerflow SAE 0W-30 50200/50500
Castrol Castrol SLX Professional Powerflow C3 SAE 0W-30 50200/50500
Castrol Castrol SLX Professional Powerflow Longlife SAE 5W-30 50400/50700
Castrol Castrol SLX Professional VW SAE 5W-40 50200/50500/50501
Castrol Castrol SLX Turbo-Diesel SAE 0W-30 50200/50500
Castrol Castrol Syntec SAE 5W-40 50200/50500
Castrol Castrol Syntec 0W-30 European Formula SAE 0W-30 50200/50500
Castrol Castrol Syntec European Formula SAE 0W-30 50200/50500
Castrol Castrol TXT 505 01 SAE 5W-40 50200/50500/50501
Castrol Castrol TXT 507 00 SAE 5W-30 50400/50700
Castrol Castrol TXT Softec Plus SL SAE 5W-30 50200/50500
Cepsa Cepsa Star Mega Synthetic SAE 0W-30 50200/50500
Cepsa Cepsa Star Mega Synthetic SAE 5W-40 50200/50500
Cepsa Cepsa Star TDI Sy nt SAE 5W-40 50200/50500/50501
Chevron Caltex Havoline Fully Synthetic SAE 5W-40 50200/50500
Chevron Havoline Synthetic DS SAE 0W-30 50200/50500
Chevron Havoline Ultra SAE 5W-40 50200/50500
Chevron Havoline Ultra S SAE 5W-30 50200/50500
Chevron Havoline Ultra S SAE 5W-40 50200/50500
Chevron Havoline Ultra S SAE 5W-40 50200/50500/50501
Chevron Havoline Ultra V SAE 5W-30 50400/50700
Cyclon Hellas Cyclon F1 Racing SAE 5W-40 50200/50500
De Oliebron TOR Extendo SAE 5W-30 50400/50700
De Oliebron TOR Specialsynth SAE 5W-40 50501
Delek Delkol Motorsynth FE SAE 5W-30 50200/50500
Delek Delkol Motorsynth TDI SAE 5W-40 50200/50500/50501
Denicol Denicol Pro Syn 4 SAE 5W-40 50500/50501
Denicol Denicol Syn Extra Long Life III SAE 5W-30 50400/50700
Duckhams Duckhams QS Premium MO SAE 5W-40 50200/50500
Elf Elf Excellium SAE 0W-30 50200/50500
Elf Elf Excellium C3 SAE 5W-30 50200/50500/50501
Elf Elf Excellium DID SAE 5W-30 50200/50500/50501
Elf Elf Excellium DID SAE 5W-40 50200/50500/50501
Elf Elf Excellium DID SAE 5W-40 50500/50501
Elf Elf Excellium Full tech SAE 0W-30 50200/50500
Elf Elf Solaris LSX SAE 5W-30 50200/50500/50501
Engen Petroleum Engen Formula 505.01 SAE 5W-40 50200/50500/50501
Engen Petroleum Engen Xtreme SAE 5W-40 50200/50500
ENI R&M Division Agip Formula Prestige SAE 5W-40 50200/50500/50501
Enoc Protec X-treme SAE 5W-40 50200/50500
Esso Esso 505 01 SAE 5W-30 50200/50500/50501
Esso Esso Megatron SAE 5W-40 50200/50500
Esso Esso Ultron SAE 5W-40 50200/50500
Esso Esso Ultron Turbo Diesel SAE 5W-40 50200/50500
Esso Motor Oil Plus SAE 5W-40 50200/50500
Esso Tecar Leichtlaufmotorenoel SAE 5W-40 50200/50500
Esso Tecar Motorenoel 505 01 SAE 5W-30 50200/50500/50501
Esso Tecar Supersyn SAE 5W-40 50200/50500
Eurol Eurol Super Lite SAE 5W-40 50200/50500
Eurol Eurol Turbo DI SAE 5W-40 50200/50500/50501
Eurol XADO SL/CF SAE 5W-40 50200/50500
Fina Fina Delta 505.01 SAE 5W-40 50500/50501
Fina Fina First 500 SAE 5W-30 50200/50500/50501
Fina Fina First 600 SAE 0W-30 50200/50500
FL Selenia Aktual Fully Synth SAE 5W-40 50200/50500
FL Selenia Pulsar Progress SAE 5W-40 50500/50501
FL Selenia Selenia Benzina Multi Valves Generation SAE 5W-40 50200/50500
FL Selenia Selenia Diesel Common Rail Generation SAE 5W-40 50200/50500
FL Selenia Selenia DIGITECH SAE 0W-30 50200/50500
FL Selenia Selenia K SAE 5W-40 50200/50500
FL Selenia Selenia K Pure Energy SAE 5W-40 50200/50500/50501
FL Selenia Selenia Multipower C3 SAE 5W-30 50200/50500/50501
FL Selenia Selenia Performer SAE 5W-40 50500/50501
FL Selenia Selenia WR SAE 5W-40 50200/50500
Fuchs Fuchs TITAN GT1 Longlife III SAE 5W-30 50400/50700
Fuchs Fuchs TITAN GT1 PRO C-3 SAE 5W-30 50400/50700
Fuchs Fuchs TITAN Supersyn SAE 0W-30 50200/50500
Fuchs Fuchs TITAN Supersyn SAE 5W-30 50200/50500
Fuchs Fuchs TITAN Supersyn SAE 5W-40 50200/50500
Fuchs Labo RC SAE 0W-30 50200/50500
Fuchs Labo Syntha High Tech Synthese SAE 5W-40 50500/50501
Fuchs TITAN Formel MC SAE 5W-40 50200/50500
Fuchs Titan GT1 SAE 5W-30 50200/50500
Fuchs TITAN Supersyn LONGLIFE SAE 5W-30 50200/50500
Fuchs TITAN Supersyn PLUS SAE 5W-40 50200/50500/50501
Galp energia Galp Energy Plus SAE 5W-40 50200/50500
Galp energia Galp Energy Premium Plus SAE 10W-40 50200/50500
Galp energia Galp Energy SP SAE 5W-40 50200/50500
Galp energia Galp Energy Ultra LS SAE 5W-40 50200/50500
Galp energia Galp Formula 1 Plus SAE 5W-40 50200/50500
Galp energia Galp Formula 505 SAE 5W-40 50200/50500/50501
Galp energia Galp Formula 505 SAE 5W-40 50500/50501
Galp energia Galp Formula TD Plus SAE 5W-40 50200/50500
Galp energia Galp Formula XLD SAE 5W-40 50200/50500
Gamaparts GAMAPARTS Super LL SAE 10W-40 50200/50500
GEMA Formula SAE 10W-40 50200/50500
GEMA Formula S SAE 5W-40 50200/50500
Ginouves York 742 SAE 5W-40 50500/50501
Ginouves York 848 SAE 5W-40 50200/50500/50501
Ginouves York 940 SAE 5W-30 50400/50700
Ginouves York 948 SAE 5W-30 50200/50500
GMC Oil GML Oil Eternity TDI SAE 5W-40 50500/50501
Gulf Gulf Formula GX SAE 5W-30 50200/50500
Gulf Oil Gulf Formula G SAE 5W-30 50200/50500
Gulf Oil Gulf Formula G SAE 5W-40 50200/50500
Gulf Oil Gulf Formula GVX SAE 5W-30 50400/50700
Gulf Oil Gulf Formula ULE SAE 5W-30 50200/50500/50501
Gulf Oil Gulf Formular G SAE 0W-30 50200/50500
Gulf Oil Gulf TEC Plus SAE 5W-40 50500/50501
Gulf Oil Gulf Ultrasynth SAE 10W-40 50200/50500
Igol Igol Profive 505.01 SAE 5W-40 50200/50500/50501
Igol Igol Profive Gold SAE 5W-40 50200/50500/50501
Igol Igol Profive Silver SAE 5W-30 50200/50500/50501
Igol Process 505.01 SAE 5W-40 50200/50500/50501
Igol Process Compact M SAE 5W-30 50200/50500
INA INA Delta Sint SAE 10W-40 50200/50500
INA INA Millennium SAE 5W-40 50200/50500
Iranol Iranol 30,000 SAE 5W-40 50200/50500
Jet Jet Top Level SAE 0W-30 50200/50500
Kendall Motor Oil Kendall GT-1 Full Synthetic Motor Oil SAE 5W-40 50200/50500
Kroon-Oil Helar SP LL03 SAE 5W-30 50400/50700
Kuttenkeuler Sorotec Pdi SAE 5W-40 50200/50500/50501
Kuwait Petroleum Q8 Formula Excel SAE 5W-40 50200/50500
Kuwait Petroleum Q8 Formula V Long Life SAE 5W-30 50400/50700
Kuwait Petroleum Q8 Motoroil 505 01 SAE 5W-40 50500/50501
Liqui Moly Liqui Moly Diesel High Tech SAE 5W-40 50000/50500/50501
Liqui Moly Liqui Moly Leichlauf HC 7 SAE 5W-40 50200/50500
Liqui Moly Liqui Moly Leichtlauf Special LL SAE 5W-30 50200/50500
Liqui Moly Liqui Moly Longtime High Tech SAE 5W-30 50200/50500/50501
Liqui Moly Liqui Moly Nachfüllöl SAE 5W-40 50500/50501
Liqui Moly Liqui Moly Pro-Engine M 300 SAE 5W-30 50200/50500
Liqui Moly Liqui Moly Pro-Engine M 400 SAE 5W-40 50200/50500/50501
Liqui Moly Liqui Moly Pro-Engine M 500 SAE 5W-30 50200/50500/50501
Liqui Moly Liqui Moly Pro-Engine M 600 SAE 5W-30 50400/50700
Liqui Moly Liqui Moly Profi Premium SAE 5W-40 50200/50500
Liqui Moly Liqui Moly Synthoil Longtime SAE 0W-30 50200/50500
Liqui Moly Liqui Moly Top Tec 4100 SAE 5W-40 50200/50500/50501
Liqui Moly Liqui Moly Top Tec 4200 SAE 5W-30 50400/50700
Longpan Petrochemical Sonic 9000 SAE 5W-40 50200/50500
Lotos Lotos Economic SAE 5W-30 50200/50500
Lotos Lotos Economic SL/CF SAE 5W-30 50200/50500
Lotos Lotos Syntetic SL/SJ/CF/CD SAE 5W-40 50200/50500
Lotos Lotos Traffic SAE 5W-40 50200/50500
Lotos Lotos Traffic Diesel 505.01 SAE 5W-40 50200/50500/50501
Lotos Lotos Traffic Thermal Control SL/CF SAE 5W-40 50200/50500
Lotos Lotos Traffic Turbodiesel CF SAE 5W-40 50200/50500
Lukoil Lukoil Synthetic SAE 5W-40 50200/50500
Lukoil Lukoil-Synthetic SAE 5W-40 50200/50500
Meguin megol Motorenoel Compatible SAE 5W-30 50400/50700
Meguin megol Motorenoel Low Emission SAE 5W-40 50200/50500/50501
Meguin megol Motorenoel New Generation SAE 5W-30 50200/50500/50501
Meguin megol Motorenoel Power Synt SAE 10W-40 50200/50500
Meguin megol Motorenoel Super Leichtlauf Multisynth SAE SAE 0W-30 50200/50500
Meguin megol Motorenoel Super Leichtlauf Technology SAE 5W-40 50500/50501
Meguin megol Motorenoel Ultra Performance Longlife SAE 5W-40 50200/50500
Meguin megol Motorenoil Quality SAE 5W-30 50200/50500
Meguin Meister-Öl Super Leichtlauf -Motorenöl SAE 5W-40 50200/50500
Meguin Motorenoel Ultra Performance Longlife SAE 5W-40 50200/50500
Millers Oils Millers XF Longlife SAE 5W-30 50400/50700
Minerva Minerva TSV SAE 5W-30 50400/50700
Mobil Mobil 1 SAE 0W-40 50200/50500
Mobil Mobil 1 SAE 5W-40 50200/50500
Mobil Mobil 1 Arctic SAE 0W-40 50200/50500
Mobil Mobil 1 ESP Formula SAE 5W-30 50400/50700
Mobil Mobil 1 Formula C SAE 0W-40 50200/50500
Mobil Mobil 1 New Life SAE 0W-40 50200/50500
Mobil Mobil 1 New Life Turbo Diesel SAE 0W-40 50200/50500
Mobil Mobil 1 Turbo Diesel SAE 0W-40 50200/50500
Mobil Mobil 1 Turbo Diesel SAE 5W-40 50200/50500
Mobil Mobil Formula X2 SAE 5W-40 50200/50500
Mobil Mobil SHC Formula V SAE 5W-30 50400/50700
Mobil Mobil Special X SAE 5W-40 50200/50500
Mobil Mobil Super 3000 Formula V SAE 5W-30 50400/50700
Mobil Mobil Super 3000 X1 SAE 5W-40 50200/50500
Mobil Mobil Super 3000 X2 SAE 5W-40 50200/50500
Mobil Mobil Super 3000 X2 Turbo Diesel SAE 5W-40 50200/50500
Mobil Mobil Synt S SAE 5W-40 50200/50500
Mobil Mobil Synt S ESP SAE 5W-30 50200/50500
Mobil Mobil Synt S Turbo Diesel SAE 5W-40 50200/50500
Mobil Mobil Syst S Special V SAE 5W-30 50200/50500/50501
Mobil Tecar 50501 SAE 5W-30 50200/50500/50501
Modrica Optima Eco SAE 5W-30 50200/50500/50501
MOL MOL Dynamic Gold SAE 5W-30 50200/50500/50501
MOL MOL Dynamic Gold Longlife SAE 5W-30 50400/50700
MOL MOL Dynamic Max SAE 10W-40 50200/50500
MOL MOL Dynamic Prima SAE 5W-40 50200/50500/50501
Morris Lubricants Morris Multilife V-MAX SAE 5W-30 50400/50700
Motul Motul 6100 Synergie + SAE 10W-40 50200/50500
Motul Motul 8100 X-cess SAE 5W-40 50200/50500
Motul Motul 8100 X-clean SAE 5W-40 50200/50500
Motul Motul 8100 X-clean SAE 5W-40 50200/50500/50501
Motul Motul 8100 X-lite SAE 0W-30 50200/50500
Motul Motul 8100 X-max SAE 5W-30 50200/50500
Motul Motul 8100 X-max SAE 5W-40 50200/50500
Motul Motul H-Tech Multi Standard SAE 5W-40 50200/50500
Motul Motul Specific 505 01 SAE 5W-40 50200/50500/50501
Motul Motul Specific 505 01 SAE 5W-40 50500/50501
Motul Motul Specific 505 01 502 00 505 01 SAE 5W-40 50200/50500/50501
Motul Motul Synergie SAE 5W-40 50200/50500
MRD Motor Gold Highline SAE 0W-30 50200/50500
MRD Motor Gold Supertec SAE 5W-40 50200/50500
MRD Motor Gold Supertec PD SAE 5W-40 50500/50501
Neste Oil Neste City Pro SAE 5W-40 50200/50500
NIS Oil Refinery Beograd Galax Sint 502 SAE 10W-40 50200/50500
Norsk-Pennsylvansk DynoCat Neutron CXS SAE 5W-30 50200/50500/50501
Norsk-Pennsylvansk DynoCat Neutron CXS SAE 5W-40 50200/50500/50501
Northland Synergy Synthetic EuroSyn SAE 5W-40 50200/50500
Oel-Brack Midland Synova SAE 5W-40 50200/50500/50501
Oel-Brack Midland Synqron SAE 5W-40 50200/50500
Oest OEST Gigant LS Plus SAE 5W-30 50200/50500/50501
Ölwerke Julius Schindler Econo Veritas XL-HC SAE 5W-40 50200/50500
Ölwerke Julius Schindler OJS Econo-Veritas Longlife III SAE 5W-30 50400/50700
Ölwerke Julius Schindler OJS Econo-Veritas OM Extra SAE 0W-30 50200/50500
Ölwerke Julius Schindler OJS Econo-Veritas XL-HC SAE 5W-40 50200/50500
Ölwerke Julius Schindler OJS Econo-Veritas XV SAE 5W-40 50200/50500/50501
Ölwerke Julius Schindler OJS Engine Oil SAE 5W-40 50200/50500
Ölwerke Julius Schindler OJS Meister-Öl Premium-Motorenöl SAE 0W-40 50200/50500
Ölwerke Julius Schindler OJS Platinum Vollsynthese SAE 0W-40 50200/50500
Ölwerke Julius Schindler OJS Veritas Syntolube SAE 0W-40 50200/50500
OMV OMV BIXXOL extra SAE 5W-40 50200/50500
OMV OMV BIXXOL extra Diesel SAE 10W-40 50200/50500
OMV OMV BIXXOL premium SAE 5W-40 50200/50500
OMV OMV BIXXOL premium Diesel SAE 5W-40 50200/50500
OMV OMV BIXXOL special C3 SAE 5W-30 50200/50500/50501
OMV OMV BIXXOL special G SAE 5W-30 50200/50500
OMV OMV BIXXOL special V7 SAE 5W-30 50400/50700
OMV OMV control light SAE 10W-40 50200/50500
OMV OMV eco extra SAE 5W-30 50400/50700
OMV OMV syncom SAE 5W-40 50200/50500
OMV OMV syncom diesel SAE 5W-40 50500/50501
Opet Opet OXT Formula V 507 SAE 5W-30 50400/50700
Orlen Oil Orlen Platinum Vollsy nthese SAE 0W-40 50200/50500
Orlen Oil Plantinum Synthetic SM/SL/CF SAE 5W-40 50200/50500
Orlen Oil Platinum MaxEnergy Euro 4 SAE 5W-30 50200/50500
Orlen Oil PLATINUM MAXENERGY EURO4 SAE 5W-30 50200/50500
Panolin Panolin Avanis SV-X SAE 5W-30 50400/50700
Panolin Panolin Daytona SAE 5W-40 50000/50500/50501
Panolin Panolin Daytona SAE 5W-40 50500/50501
Paramo Mogul Extreme SAE 5W-40 50200/50500
Paramo Mogul Racing S Pro SAE 5W-40 50500/50501
Paz Lubricants & Chemicals Ltd Top Paz SAE 5W-40 50200/50500/50501
Pennzoil Pennzoil Platinum European Formula SAE 5W-40 50200/50500
Pennzoil Pennzoil Platinum European Formula Ultra SAE 5W-30 50200/50500
Pennzoil Pennzoil Platinum European Ultra Diesel SAE 5W-30 50200/50500/50501
Pennzoil Pennzoil Platinum Low SAPS SAE 5W-30 50200/50500/50501
Pennzoil Pennzoil Platinum VX SAE 5W-30 50400/50700
Pennzoil Pennzoil Synthetic European Formula SAE 5W-40 50200/50500
Penrite Oil ENVIRO + SAE 5W-30 50400/50700
Pentosin Pento High Performance SAE 5W-30 50200/50500
Pentosin Pento High Performance SAE 5W-40 50200/50500
Pentosin Pento High Performance II SAE 5W-40 50200/50500/50501
Pentosin Pento Super Performance III SAE 5W-30 50400/50700
Pentosin Pentospeed VS* SAE 0W-30 50200/50500
Pentosin Pentosynth HC SAE 5W-40 50200/50500/50501
Petro China KUNLUN Tianrun SAE 5W-40 50200/50500
Petro China Kunlun Tianrun SAE 5W-40 50200/50500/50501
Petro China Kunlun Tianyuan SM SAE 5W-40 50200/50500/50501
Petrol Petrol 505.01 5W-40 SAE 5W-40 50500/50501
Petrol Of isi PO Maxima SAE 5W-40 50200/50500
Petrol Of isi PO Maxima Diesel SAE 5W-40 50200/50500
Petronas Petronas Syntium 3000 SAE 5W-40 50200/50500
Petronas Petronas Syntium 5000 AV SAE 5W-30 50400/50700
Poweroil High-Tech-Schmierstoff Poweroil High-Tech-Schmierstoffevollsynth. SAE 0W-40 50200/50500
Poweroil High-Tech-Schmierstoff Poweroil High-Tech-Schmierstoffe Longlife SAE 5W-30 50400/50700
Prista Oil Prista Ultra SAE 5W-40 50200/50500
Prof i-Tech Prof i-Car Synth Tech XT SAE 5W-40 50200/50500
PTT Public Company Limited Limited Performa Euro Syn SAE 5W-40 50200/50500/50501
PTT Public Company Limited Performa Euro Syn SAE 5W-40 50200/50500/50501
Quaker State Q Diesel Plus SAE 5W-30 50400/50700
Quaker State Q European Engine VX SAE 5W-30 50400/50700
Quaker State Quaker State Synquest SAE 5W-40 50200/50500
Quaker State Quaker State Synquest Low SAPS SAE 5W-30 50200/50500/50501
Quantum Quantum Longlife III SAE 5W-30 50400/50700
Quantum Quantum PD Diesel SAE 5W-40 50200/50500/50501
Quantum Quantum Synta ED SAE 0W-30 50200/50500
Quantum Quantum Synta Gold SAE 5W-40 50200/50500
Rafinerija Modrica Galax Racing SAE 5W-40 50200/50500
Rafinerija Modrica Optima 505 01 SAE 5W-40 50500/50501
Ravensberger Schmierstoffvertrieb Ravenol Super Synthetic SSO SAE 0W-30 50200/50500
Ravensberger Schmierstoffvertrieb Ravenol VPD SAE 5W-40 50200/50500/50501
Ravensberger Schmierstoffvertrieb Reratrvieebnol Hydrocrack Synth. HCS SAE 5W-40 50200/50500
Ravensberger Schmierstoffvertrieb Reratrvieebnol VSI SAE 5W-40 50200/50500
real real,- Quality GPD SAE 5W-40 50200/50500/50501
real real,- Quality GSL SAE 5W-30 50400/50700
real real,- Quality GSR SAE 5W-30 50200/50500
Redoil Italia Challoils Ultrasynt SAE 5W-40 50200/50500/50501
Repsol Repsol Elaion Full Performance SM SAE 5W-40 50200/50500
Repsol Repsol Elite 50501 TDI SAE 5W-40 50200/50500/50501
Repsol Repsol Elite 50501 TDI SAE 5W-40 50500/50501
Repsol Repsol Elite Competicion SAE 5W-40 50200/50500
Repsol Repsol Elite Cosmos SAE 0W-40 50200/50500
Repsol Repsol Elite Evolution SAE 5W-40 50200/50500
Repsol Repsol Elite Multivalvulas SAE 10W-40 50200/50500
Rothen Oil Rothen Extrasynth SAE 5W-30 50200/50500/50501
Rowe Hightec Synth RS 5W-40i SAE 5W-40 50200/50500
Rowe Rowe HIGHTEC ECOSYNT Longlife III SAE 5W-30 50400/50700
Rowe Rowe Synt - HC SAE 5W-40 50200/50500
Rowe Rowe Synt PD SAE 5W-40 50200/50500/50501
Rowe Rowe Synt RS DLS SAE 5W-30 50200/50500/50501
Rowe Rowe Synt RS HC-FE SAE 5W-30 50200/50500
SCT Mannol Extreme SAE 5W-40 50200/50500
Seventy -Six Lubricants 76 Pure Synthetic Motor Oil SAE 5W-40 50200/50500
Shanghai Lizhong LiZhong No.1 SAE 5W-30 50400/50700
Shanghai Lizhong LUHU SAE 5W-40 50200/50500/50501
Shanghai Tempo Tempo 8000-1A SAE 5W-40 50200/50500
Shanghai Tempo Petrochem Tempo 8000-1C SAE 5W-40 50200/50500
Shell Formula Shell Ultra AB SAE 5W-30 50200/50500
Shell PKW Motorenöl SAE 5W-40 50200/50500
Shell Q Diesel Plus SAE 5W-40 50200/50500/50501
Shell Q European Engine Ultra SAE 5W-30 50200/50500
Shell Q European Engine Ultra SAE 5W-40 50200/50500
Shell Q European Engine Ultra Diesel SAE 5W-30 50200/50500/50501
Shell Q Horsepower Full Synthetic SAE 5W-40 50200/50500
Shell Shell Helix Diesel HX7 C SAE 5W-40 50200/50500
Shell Shell Helix Diesel Plus SAE 5W-30 50200/50500
Shell Shell Helix Diesel Plus SAE 5W-40 50200/50500
Shell Shell Helix Diesel Plus VA SAE 5W-30 50200/50500/50501
Shell Shell Helix Diesel Plus VA SAE 5W-40 50200/50500/50501
Shell Shell Helix Diesel Ultra SAE 0W-40 50200/50500
Shell Shell Helix Diesel Ultra SAE 5W-30 50200/50500
Shell Shell Helix Diesel Ultra SAE 5W-40 50200/50500
Shell Shell Helix Diesel Ultra E SAE 5W-30 50200/50500
Shell Shell Helix Diesel Ultra Extra SAE 5W-30 50400/50700
Shell Shell Helix Diesel Ultra VA SAE 5W-30 50200/50500/50501
Shell Shell Helix HX7 SAE 5W-30 50200/50500
Shell Shell Helix HX7 SAE 5W-40 50200/50500
Shell Shell Helix HX7 C SAE 5W-40 50200/50500
Shell Shell Helix Plus SAE 10W-40 50200/50500
Shell Shell Helix Plus SAE 5W-30 50200/50500
Shell Shell Helix Plus SAE 5W-40 50200/50500
Shell Shell Helix Plus AR SAE 10W-40 50200/50500
Shell Shell Helix Plus Extra SAE 5W-40 50200/50500
Shell Shell Helix Plus S SAE 5W-30 50200/50500
Shell Shell Helix Plus S SAE 5W-40 50200/50500
Shell Shell Helix Plus SM SAE 5W-30 50200/50500
Shell Shell Helix Plus SM SAE 5W-40 50200/50500
Shell Shell Helix Plus VB SAE 10W-40 50200/50500
Shell Shell Helix Premium SAE 5W-40 50200/50500
Shell Shell Helix Ultec SAE 0W-40 50200/50500
Shell Shell Helix Ultra SAE 0W-40 50200/50500
Shell Shell Helix Ultra SAE 5W-30 50200/50500
Shell Shell Helix Ultra SAE 5W-40 50200/50500
Shell Shell Helix Ultra AM SAE 5W-30 50200/50500
Shell Shell Helix Ultra AM SAE 5W-40 50200/50500
Shell Shell Helix Ultra AV-L SAE 5W-30 50400/50700
Shell Shell Helix Ultra AX SAE 5W-30 50200/50500/50501
Shell Shell Helix Ultra C SAE 0W-40 50200/50500
Shell Shell Helix Ultra E SAE 5W-30 50200/50500
Shell Shell Helix Ultra Extra SAE 5W-30 50400/50700
Shell Shell Helix Ultra Extra Polar SAE 0W-40 50200/50500
Shell Shell Helix Ultra VX SAE 5W-30 50400/50700
SIG Car Jack GPD SAE 5W-40 50200/50500/50501
Singapore Petroleum SPC Syn Ace API SM/CF SAE 5W-40 50200/50500
Sinopec Blue Spirit SAE 5W-40 50500/50501
Sinopec Great Wall Ultra Gold V5457 SAE 5W-30 50400/50700
Sinopec Polar Star SAE 5W-40 50200/50500
Sinopec Polar Star III SAE 5W-40 50200/50500/50501
Sinopec Ultra Gold SAE 5W-40 50200/50500/50501
SK energy ZIC RV SAE 5W-30 50200/50500
SK energy ZIC XQ SAE 5W-40 50200/50500
SK energy ZIC XQ RV SAE 5W-40 50200/50500
S-Oil Corporation SSU EURO XT SAE 5W-30 50200/50500
S-Oil Corporation SSU EURO XT SAE 5W-40 50200/50500
Sonol Sonol Synt 502.00 SAE 5W-40 50200/50500
Sonol Sonol Synt 505.01 SAE 5W-40 50500/50501
Startol RASANTA SPECIALSYNT SAE 5W-40 50000/50500/50501
Startol Startol Rasanta Specialsynth Pdi SAE 5W-40 50200/50500/50501
Startol Startol Transit Diplomat Longlife III SAE 5W-30 50400/50700
Statoil PRO Synthetic C SAE 5W-40 50200/50500/50501
Statoil Statoil LazerWay SAE 5W-40 50200/50500
Statoil Statoil LazerWay C SAE 5W-40 50000/50500/50501
Statoil Statoil LazerWay C SAE 5W-40 50200/50500
Statoil Statoil LazerWay LL SAE 5W-30 50400/50700
Statoil Statoil LazerWay TDI SAE 5W-40 50200/50500
Statoil Statoil PRO Synthetic SAE 5W-40 50200/50500
Sun Oil Sunoco Ultra semi-synthetic SAE 5W-40 50500/50501
Sunlight Sunlight Fully power F-1A SAE 5W-40 50200/50500
SWD Concep-Tech HDC SAE 5W-40 50200/50500
SWD Concep-Tech Synth. SAE 5W-40 50000/50500/50501
SWD Concep-Tech Synth. SAE 5W-40 50500/50501
SWD GECCO Motorenöl HC SAE 5W-40 50200/50500
SWD GECCO Motorenöl SY SAE 5W-40 50500/50501
SWD GECCO Motorenöl VZW SAE 5W-30 50400/50700
SWD swd PRIMUS DX SAE 5W-30 50200/50500/50501
SWD swd Primus HDC SAE 5W-40 50200/50500
SWD swd PRIMUS LLX SAE 5W-30 50400/50700
SWD swd Primus Synth. SAE 5W-40 50000/50500/50501
SWD swd Primus Synth. SAE 5W-40 50500/50501
TACTI Corporation Castle Euaro 502 SAE 5W-40 50200/50500
TACTI Corporation Castle Euaro 504 SAE 5W-30 50400/50700
Tamoil Tamoil SINT FUTURE EXTRA SAE 5W-40 50200/50500/50501
Tamoil Tamoil Sint Future Longlife III SAE 5W-30 50400/50700
Tamoil Tamoil Sint Future Power SAE 5W-30 50400/50700
Tamoil Tamoil SINT FUTURE RACING SAE 5W-40 50200/50500
Tecar Tecar Motorenoel SAE 5W-30 50400/50700
Tecar Tecar Motorenoel 504 00 / 507 00 SAE 5W-30 50400/50700
Tedex Tedex Synthetic Motor Oil SAE 5W-40 50200/50500/50501
Texaco Havoline 505.01 SAE 5W-40 50500/50501
TNK Lubricant LLC TNK Magnum Synthetic SAE 5W-40 50200/50500
TNK Lubricant LLC TNK Ultra SAE 5W-40 50200/50500
Total Gulf Formula Extreme SAE 0W-30 50200/50500
Total Gulf GDI Extra SAE 5W-40 50500/50501
Total Total Activa 9000 SAE 5W-40 50200/50500
Total Total Activa Diesel 9000 SAE 5W-40 50200/50500
Total Total Activa Energy 9000 SAE 0W-30 50200/50500
Total Total Quartz 505.01 SAE 5W-40 50500/50501
Total Total Quartz 9000 SAE 5W-40 50200/50500
Total Total Quartz 9000 Energy SAE 5W-40 50200/50500
Total Total Quartz Energy 9000 SAE 0W-30 50200/50500
Total Total Quartz INEO MC3 SAE 5W-30 50200/50500/50501
Unil Opal Opaljet 24 S SAE 5W-40 50200/50500
Unil Opal Opaljet Energy 3 SAE 5W-30 50400/50700
Unil Opal Opaljet Futura SAE 5W-40 50200/50500/50501
Unil Opal Opaljet Futura SAE 5W-30 50400/50700
United Oil United 1 Fully Synthetic SAE 5W-40 50200/50500
Valvoline Synpower MST SAE 5W-30 50200/50500/50501
Valvoline Synpower MST SAE 5W-40 50200/50500/50501
Valvoline Valvoline DuraBlend MXL SAE 5W-40 50200/50500
Valvoline Valvoline SynPower HST SAE 5W-40 50200/50500/50501
Valvoline Valvoline Synpower MST SAE 5W-30 50200/50500/50501
Valvoline Valvoline SynPower XL-III SAE 5W-30 50400/50700
VAPS Vapsoil 502 00 SAE 5W-40 50200/50500
VAPS VAPSOIL 505 01 SAE 5W-40 50000/50500/50501
VAPS Vapsoil 505 01 SAE 5W-30 50200/50500/50501
VAPS Vapsoil 505 01 SAE 5W-40 50200/50500/50501
VAPS VAPSOIL 507 00 SAE 5W-30 50400/50700
Vial Oil Consol Ultima SAE 5W-40 50200/50500
Volkswagen Mexico Audi, Seat, VW Aceite para Motor a Gasoline SAE 5W-40 50200/50500
Volkswagen Original Teile Volkswagen LongLife III SAE 5W-30 50400/50700
Volkswagen Original Teile ® Motorenoel G 052 167 A2 SAE 5W-40 50000/50500/50501
Volkswagen Original Teile ® Volkswagen Special plus SAE 5W-40 50200/50500/50501
Weco Weco TXI Sy ntolube SAE 5W-40 50200/50500
Westfalen AG Westfalen Gigatron SAE 0W-40 50200/50500
Westfalen AG Westfalen Mega Tron SAE 5W-40 50200/50500
Wintershall - SRS SchmierstoWf Wintershall ViVA 1 longlife SAE 5W-30 50200/50500
Wintershall - SRS SchmierstoWf Wintershall ViVA 1 longlife topsynth SAE 5W-40 50200/50500
Wintershall - SRS SchmierstoWf Wintershall ViVA 1 longlife topsynth alpha SAE 5W-30 50200/50500
Wintershall - SRS SchmierstoWf Wintershall ViVA 1 longlife topsynth alpha LA SAE 5W-30 50200/50500/50501
Wolf Startol Rasanta Specialsynth Pdi SAE 5W-40 50200/50500/50501
Wolf Wolf Masterlube Synflow DC SAE 5W-40 50200/50500
Wolf Wolf Masterlube Synflow LL III SAE 5W-30 50400/50700
Wolf Wolf Masterlube Synflow PI SAE 5W-40 50200/50500/50501
Würth Triathlon Endurance III SAE 5W-30 50400/50700
Würth Triathlon Formula LL SAE 5W-30 50200/50500
Würth Triathlon Performance SAE 5W-40 50200/50500/50501
Würth Triathlon Special PD SAE 5W-40 50200/50500/50501
Yacco Yacco VX 1000 SAE 5W-40 50200/50500
Yacco Yacco VX 1703 FAP SAE 5W-30 50200/50500/50501
Yacco Yacco VX 1703 FAP SAE 5W-40 50200/50500/50501
Yacco Yacco VX 505 SAE 5W-40 50500/50501
Yacco Yacco VX 600 SAE 5W-40 50200/50500
YPF YPF Elaion Full Perf ormance SM SAE 5W-40 50200/50500
Zeller+Gmelin Divinol Syntholight SAE 0W-40 50200/50500
Zeller+Gmelin Divinol Syntholight SAE 5W-40 50200/50500
You can get Mobil 1 0w-40 at a Walmart.
Why do you have to lie to the customer service rep that you can't find an oil in Reno on the list?
It sounds to me like you knew how the conversation was going to go and wanted to be a bit of a troll, and I think the rep did a great job giving the info she had available.
Not being a troll. I went to Oreilly's and Walmart. Neither had a 5-40 oil with the 502.00 certification.
I've seen Castrol 5w-40 at AAP as well as at AZ, but personally I wouldn't use it.
Also, most Walmart stores carry Valvoline Synpower 5w-40 which meets VW 502.00 spec.
The same Valvoline oil can often be found at NAPA. NAPA typically also carries Lubro Moly 5w-40 that meets the spec.
Shows available on walmart's website?
Mobil 1 0W-40 Advanced Full Synthetic Motor Oil, 5 qt.
5 out of 5
Open Ratings Snapshot
(83 Customer Reviews) Write a review |
Q&A | About this product
Print
Shop at Walmart
Pickup Information
$22.66
Quantity
Add to Cart
Add to my:
Wish List
|Registry
In Stock for:
Free store pickup at Reno
– as soon as today with Site to Store Check More Stores
5 out of 5
Print
Shop at Walmart
Pickup Information
$22.66
Quantity
Add to Cart
Add to my:
Wish List
|Registry
In Stock for:
Chickipoo at VW says being on the approved list is not enough. It must also be 5-30 or 5-40. Not available at my local Walmart or Oreilley's.
Pretty arrogant! Especially when another part of the owner manual says you can use other weights if the one specified is not locally available and the weight is suitable for your area. What could be more suitable than 0-40?
That was hilarious!!
I think I see your problem, Its a VW.....
You couldn't pay me to own a VW. Let me know how you are doing when it hits 90-100K.....
Wayne
VW Norm 502.00 is a quality/performance standard specified by Volkswagen. The viscosity is chosen based on climate where vehicle is operated. It's that simple.
The lady at Volkswagen of America is wrong with her understanding as exhibited by her conversation. Unfortunately this is all too often the case.
Use your 0W-40/5W-40/5W-30/0W-30, etc so long as it carries the 502.00 rating. This nonsense is exactly what keeps VW's market share in the single digits.
Pretty sure she is not allowed to have any understanding. She is to recite what's in the owner's manual and/or script.
Even still, the owner's manually specifically states:
"Always use an approved oil that meets Volkswagen oil quality standard VW 502.00 (gasoline engine)..."
If viscosity grade 5W-40 or 5W-30 is not available in your area, be sure to use a viscosity grade suitable for the climate, season and operating conditions that exist where the vehicle is operated. Make sure the oil meets the quality standard listed above."
This is verbatim from the owner's manual. Not much left open to interpretation if you ask me.
As if other manufacturers didn't have specific grade and/or spec requirements.
Wayne
Probably better then most of the cars.
This is not only VW thing, it is generally problem in any customer service department where you have people working for a minimum wage without any knowledge of the thing that they are talking about.
I just closed on a house. I had to explain people in the bank how to deal with debt to income ratio since I am only one going on the loan. If I left to them I would be still renting apartment.
OP:
Just use ANY VW 502.00. If something happens it is not Jennifer that will amke that decision but someone who knows those stuff.
Wayne
Because millions of Europeans trash their VAG vehicles after 160,000 km.
Any 502.00 will be perfect.
There are even none-502.00 that give adequate protection. Redline is a good place to start.
If you want to maintain your warranty mail order anything off the list posted above.
