- Joined
- Jul 11, 2014
- Messages
- 4,118
Use any current spec full synthetic. High mileage oil not needed unless there is oil consumption or leakage. Stick with 5w30. 0w30 can also be used. A 0w40 might mask engine noise but not needed for your climate.
You should have no problem with 6month 7.5k intervals. Oversized oil filter is an option. Keep an eye on oil level and top off as needed.
