Finally got a camera good enough to take these pic's. Bought the RV with 26k in June 13 and now has 33k. Looked like this then and nothing has changed or got worse. The crack on the back one hasn't changed and I'm sure the roughness is due to hitting curb's. The driver's rear was perfect till I hit a curb due to construction in LA now it looks the same as the passenger. The inner duals look the same though and that shouldn't be sun damage.
They're 08's Firestone Transforce HT's Load Range D with unknown mileage. I'd say they were new when the previous owner bought it from the original, she only put 1k in a year on it by the title. They've been covered when unused since I bought it probably why it hasn't changed. I know I should probably change them but thinking I bet they'll last till 2016 which they should be changed out regardless. Only drive 65 or less which I know doesn't mean much. Undecided on what I'll go with.. these are some smooth riding tires but they're D's which most are E's now days.
Back's
Back's
