Of the carbon is a result of usage patterns, you need to change usage.
That said, a water decarb is as effective as anything else you can do with the head on and cheap!
Most time efficient and thorough way I've found to clean piston tops is with the head off - let some brake cleaner sit on the carbon for 10 minutes, grab some shop towel and it wipes right off.
