I was able to the PDF open. Copied information:
Description
Castrol EDGE Professional with Fluid Strength TechnologyTM is Castrol’s strongest and most advanced range of engine
oils.
Its unique adaptive strength reduces metal-to-metal contact across a range of different driving speeds.
Castrol EDGE Professional H 0W-20 gives you the confidence to demand maximum engine performance from the latest
high-performance, efficient technology engines requiring the lowest viscosity oils.
Castrol EDGE Professional H 0W-20 is co-engineered with Honda for the latest generation engines.
Micro-filtered and with its signature fluorescent colour it is your guarantee of Professional quality.
Castrol EDGE Professional. Strength to Perform - Freedom to Drive.
Application
Castrol EDGE Professional H 0W-20 is suitable for use in automotive gasoline engines where the manufacturer
recommends an API SN, ILSAC GF-5 or earlier specification 0W-20 lubricant.
Castrol EDGE Professional H 0W-20 is co-engineered with Honda for use in Honda gasoline engines that require a 0W-
20 lubricant.
Advantages
• Maximises short and long term engine performance
• Improves engine efficiency, independently qualified
• Delivers unsurpassed levels of protection across a variety of driving conditions and temperatures
• Reduces engine deposits to help maximise engine response
Typical Characteristics
Name Method Units Castrol EDGE Professional H 0W-20
Density @ 15C, Relative ASTM D4052 g/ml 0.85
Viscosity, Kinematic 100C ASTM D445 mm²/s 8.9
Viscosity, CCS -35C (0W) ASTM D5293 mPa.s (cP) 3860
Viscosity, Kinematic 40C ASTM D445 mm²/s 39
Viscosity Index ASTM D2270 None 220
Flash Point, PMCC ASTM D93 °C 220
Product Performance Claims
API SN
ILSAC GF5
