Originally Posted By: Scott_mi
Originally Posted By: redhat
Are you out of your powertrain warranty?
Not sure if maybe you got a few months left. Usually wheel bearings on GMs are powertrain. Just a thought.
This post may be for naught. I did not think for a second that would be covered under the power train warranty. Will see if I'm in for an up hill battle, SOL, or I get taken care of.
My PT warranty expired 7-31-14. Before it expired, I took the truck in for a TBS on oil consumption and while they were doing the repair they must have done an inspection because when I picked up the truck they had 2 "service Pricing Quotes" for repairs. One of those is for the Hub and bearing assembly and the other is for leaking transmission cooler lines.
So here I sit with a dealer labeled and dated price quote for repairing the wheel hub for $632.13 showing they found it needing to be replaced prior to my warranty expiring. They never asked about my warranty or mentioned that it was covered under warranty.
Since I hate when an OP disappears and thread's have no update or ending....
Thanks for the info on brands and replacement suggestions, but a bigger thanks to radhat for the info that it could be covered under power train warranty. Went in and spoke with service adviser who spoke with service manager, who left and did something or spoke with someone....will get it covered either warranty or good will....not sure as they mentioned both. Considering I had dealer dated papers indicating it needed to be replaced prior to my warranty expiring, I figured I would eventually get it taken care of, but glad I didn't need to fight with the dealer and go through GM customer care.
