Originally Posted By: David1
The FRAM ULTRA is a great oil filter but its made for many engines.. Who knows if the bypass is the exact factory spec.
Fram wouldn't specify the Ultra for your car if the filter's design specs didn't work for your car. The aftermarket filter makers warranty the filter, and typically say it "meets or exceeds OEM specifications". Same holds true with any oil filter specified for a vehicle.
Well 2 differet sizes FRAM ULTRAs fit my car.. the 7317 and 3593A
So are are both them the same?
Also I like FRAM OIL FILTERS.... I think they are great and are best bang for the buck.
However Personally if I can get A01s with no problem, I would use the A01s
however they are harder to find then going to wallymart and paying 8$ for a FRAM ULTRA or 6$ for a FRAM TOUGH GAURD... So I have no problem with FRAM.
However if Walmart had HONDA FILTECH A01s there for 5$ I would get the A01s, I bet many would.
Also what I like about the Honda Oil filter is the Gasket... Its D shaped... I have seen or read that the D shaped gasket is better then the Regular...
also the D shaped gasket on the A01 and even A02 dont come off easy like 99% of the Gaskets on other oil filters.
Again... I like FRAM Ultra.. Not bashing FRAM.....
As long as both of the filters are actually recommended by Fram in their catalog I wouldn't worry about it. Fitting and recommended are two different things entirely.
