I already had some Amsoil Severe Gear 75W-90 on the shelf. I originally intended to use this on the last pickup but traded it in before I could. Instead of the bottles collecting dust on the shelf, I thought I would change out the rear axle fluid on the 14. I purchased a hand pump from Harbor Freight to get the old fluid out: http://www.harborfreight.com/multi-use-transfer-pump-66418.html After removing the fill hole plug, I stuck the hose in as far as I could and pumped out the old fluid. I estimated I got at least 90% of it out judging by how much new oil I put back in (rated for 5.5 pints). This worked pretty good vs taking the cover off and disturbing the gasket. I already had a hand pump for the Amsoil quarts so that went quickly also. Maybe took a half hour to complete the job.
Fill plug is magnetic and had a good amount of metal on it. No large chunks (just a fine paste). Old fluid was very dark. Plan to do my front axle at the next engine oil change.
