I've seen them ripped, and others shattered like glass in some old Ford applications. Usually if they look good, and have the same feel as the replacements, they probably are good, although there might be some exceptions. It's hard to tell without seeing and handling them. If you replaced them because of oil consumption you could have other problems like worn valve guides, and/or sticking or worn rings.
Why did you change them?
