Oil for zero turn mower?
Dixon 5424(B&S Intek Twin): M1 5W-30
Cub Cadet Enforcer 54(Kaw Twin): M1 10W-30
My question would be why you think that stating a specific style of mower (zero turn) would correlate to a recommendation about oil.
I have a snow thrower with lights on it. Does that factor into the choice of oil?
Originally Posted By: lawnguy
Do you own a zero turn mower? I'm curious to know what type of oil you use, and why?
I believe 0W-0 is recommended for zero turn mowers ....
Many zero turn mowers, including my John Deere 757, use an engine oil for the hydraulics. Given that mine calls for 15W-40 in the hydraulics, I use 15W-40 in the engine as well.
If I didn't have a zero turn that required 15W-40 in the hydraulics, I might not use 15W-40 in the engine. Being a zero turn mower does indeed have some influence on the engine oil that a standard mower may not have.
I'm pretty sure my JD F510 recommended 5w30 for the oil. It's a shared engine hydraulic unit. The oil ran very hot. I would stick a thermocouple into the oil fill after mowing for a couple hours and it would easily be 300F.
I added an oil filter cooler bypass and ran it the oil through an plate type ATX cooler I had. Also added an oil temp gauge. I think I have the temp sender on the oil coming out of the cooler. I could not get it on the other line due to space restrictions. It now will read 210F at the most when it's really hot out after a 2 hour mow.
I use M1 0w40 now.
