Markets outside of North America and with hotter climates spec heavier oils because 0w20 is nearly impossible to find locally. It's about specing what is readily available in their market. It has NOTHING to do with heavier oils being able to protect better under normal conditions.
There was even a campaign in Asia by Toyota to get people to switch over to lighter viscosity oils. The standard in Asia used to be 20w50 and even 10w30 was hard to find. Asia has NO CAFE STANDARDS, so why would Toyota bother? Read the article yourself:
http://www.imakenews.com/lng/e_article000463014.cfm?x=b11,0,w
Originally Posted By: jrustles
Originally Posted By: Shannow
If thinner oils mean that the engines and cars wear out at closer to the same time, not only is that fuel efficient, it makes more sense in the overall life of a vehicle.
People just have to realise that
compromise is real, makes sense, and that 20s aren't there to make your engine last an extra 0.5 vehicle lifetime.
Exactly, it's not a difficult concept to grasp.
Originally Posted By: CATERHAM
When a manufacturer spec's a 20 grade oil particularly a high VI synthetic 0W-20 over a cheap heavier dino it's all about maximizing engine efficiency
Agreed.
Quote:
and minimizing engine wear when it's most likely to occur.
CITATION PLEASE!
Originally Posted By: Apollo14
I read that the Daimler now see thinner oil as inevitable for their engines also. So how much will they be compromising by going from 40 to 30?
Every manufacturer is heading there. It's a roll-out IMO. You first start with the econo-cars, in the laziest, most relaxed motoring market on the planet as was the case with 5w20 well over a decade ago.
The 0W component only indicates a higher VI fluid, with more advanced "synthetic-enhanced" chemistry, but being a Higher VI 20 grade, the 0W20 inherits it's VI on the cold side obviously, because a cold engine with cold oil is the worse case scenario
from a fuel consumption perspective- it's a 'gram strategy' for cumulative effect (fleet-wide increase in FE). I have yet to read from any official source that warm-up wear is in any way a design objective.
Quote:
None of this matters without hard facts. The
engineers determined that reducing viscosity was safe, and the ultimate test ie real world usage proved that it was.
Well, the engineers decided that reducing viscosity is 'safe' (see: acceptable)
but only in product destined to certain markets. Clearly, other more demanding motoring markets have different advice from the engineers, despite these international markets having already begun imposing CAFE-like targets.
And thus, the 0W20s in Europe's future will undoubtedly start off WAY more advanced than the fluids from our "experiment" in North America with the switch to 20 grades. Does anyone remember the first 0W20s and 0w30s? Horrible stuff.
