Originally Posted By: gregk24
Originally Posted By: Roob
In the long run it can shorten their life.
The higher restriction in airflow will cause your fan, ac compressor to work harder when using them. It can also cause an increase in gas consumption than normal when using the ac, as the compressor will be working harder due to the increased restriction of airflow.
I tried one a while ago and when my Ex Honda master mechanic saw it he almost threw it at me...
It made a big enough difference in my car anyways, but I'm pretty particular...(bad cabin air filter related joke)
Biggest crock of swill I've ever heard. Aftermarket cabin filters are OK, and the Fram Fresh Breeze is fine.
Doubt it.
Not all aftermarket items are good, some are carp. In this case, the fram fresh breeze is a nice product, but it's built like a brick. The filtering element is like dense cardboard compared to the Denso OEM that is made of high flow paper.
Quite a few reviews online about the fram fresh breeze causing a less than stellar performance in air flow, but it smells nice.
Anyhoo, I listen to professionals like the master tech Honda mechanic, I'd be stupid not to. It makes sense and after switching back I did notice a difference, but I'm very particular with my car. Some will notice and some won't.
In my experience the fram wasn't as good and seeing as the OP has the same car, different year, I thought to notify him of my experience. Hopefully it aids him and gave you something to chortle at.
I dont notice a difference, and I am pretty particular. Did your master tech actually tell you it would damage parts? Or did he just say it would impede flow of air? Really, I would like to know.
As I said, some will notice and some won't.
The tech said that long term use of the Fram fresh breeze filter "could" damage the ac compressor.
This is due to the added air flow restriction over the OEM that could cause the compressor/system to work harder. The system on my car is designed to work at its most efficient using the OEM high flow paper element cabin filter, deviating from that can have unintended consequences like impeded airflow.
Makes sense when you visually inspect each filter for comparison. Seeing as ac parts are not cheap and I had noticed more noise and a drop in airflow with the Fram all around, especially when on ac and recirculate, I've decided to take the advice.
With the OEM filter and using ac either on/off recirculate, I get a stronger/quieter airflow that is definitely noticeable.
I figure that when you have a professional who happens to be an expert on your make of car, give you advice, you should listen... However not everyone does and I don't expect everyone to, its just my experience and ymmv.
Hope that answers it for you.
