Code:
OIL M10W40 BMW5W30
MILES IN USE 6,292 8,873
MILES 125,685 70,634
SAMPLE TAKEN 08/30/14 08/19/11
Makeup Oil 0.75 qt 0.50 qt
ALUMINUM 3 5
CHROMIUM 0 1
IRON 10 17
COPPER 1 4
LEAD 1 2
TIN 0 0
MOLYBDENUM 87 160
NICKEL 0 0
MANGANESE 0 4
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 7
BORON 105 53
SILICON 5 9
SODIUM 5 16
CALCIUM 3139 2427
MAGNESIUM 25 49
PHOSPHORUS 926 934
ZINC 1067 1273
BARIUM 0 0
INSOLUBLES TR 0.2
WATER 0 0
FLASHPOINT ºF 420 360
SUS VIS 210ºF 68.8 69.6
cSt @ 212ºF 12.63 12.84
TBN 4.6 1.8
Blackstone Comments:
The engine liked the Mobil 1 just fine. In fact, almost all of the wear metals are little lower this time, though the shorter oil
run probably didn't hurt in that regard. We don't generally see much difference in wear between the various types of oil,
so either the Mobil 1 or BMW brand oil should work fine. Or try something else if you're curious. There's no fuel this time
around and the viscosity is in the correct range for 0W/40. Air and oil filtration are excellent. The TBN is 4.6, showing
active additive left. Try 9,000 miles on the oil again.
thoughts??
OIL M10W40 BMW5W30
ALUMINUM 3 5
CHROMIUM 0 1
IRON 10 17
COPPER 1 4
LEAD 1 2
TIN 0 0
MOLYBDENUM 87 160
NICKEL 0 0
MANGANESE 0 4
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 7
BORON 105 53
SILICON 5 9
SODIUM 5 16
CALCIUM 3139 2427
MAGNESIUM 25 49
PHOSPHORUS 926 934
ZINC 1067 1273
BARIUM 0 0
INSOLUBLES TR 0.2
WATER 0 0
TBN 4.6 1.8
thoughts??
