If all you wanted to clean was the valves, combustion chamber(s) and the top of the piston(s), All one would have to do is pour a little(I'll say it again, a LITTLE water) down the carb as the engine is running and they will be as clean as a new engine.
On one of our turbo cars we run water/meth injection and when we pulled the heads to repaint the tops of our pistons every thing was so clean, you could eat off it.
ROD
ROD
