Originally Posted By: ZeeOSix
Originally Posted By: lawman1909
Tell me if this is right, I am sure it is. My one good spam can is solid tight (metal spam can wont allow me to push the metal in towards the ammo), however with this one, the top of the lid is pushed slightly up so you can see what it was once molded onto the rest of the spam can and the sides are loose (I can push the metal in and it will retract back out). That to me is clear evidence of a seal broken. It is pushed back out by the air moving back into the container.
If you want to be sure, empty the can then submerge it under water for 5 min to test the seal. Then remove it, dry the outside off and open it up to see if there is any water inside.
It's a "spam can", not the resealable type.
Like this...
Like this...
