In truth, it doesn't matter. they're all compatible in grade and service, then all of the oils are compatible and will work. Mobil1 is not somehow magical and made of unicorn tears.
But if it makes you feel better, then you might use the theory that as long as the top-off oil's service time will make it to the end of the OCI, then use that oil. So say your PYB has a 5000mile (life). If you add that at 7500 until OCI then that's a no-no.
There are others in the camp that oil doesn't go bad, it's just the additives, so in oil-consuming cars, as long as you're replenishing additives then you're fine, you can go on forever without a change (just filters).
Finally, there are those that say why are you pinching pennies. Just put in the best all the time. You already made the decision to put mobil1 since you thought it's "better" and worth it's cost, what changes your mind about the "topoff" oil. Your same logic that mobil1 is better should still hold. And it's not like mobil1 is so expensive it will cause you to starve.
Pick any strategy you want. As long as YOU are good with your decision then it's fine.
