Originally Posted By: aquariuscsm
Is it ticking at every startup,or just that one very first startup? Did you pre-fill the filter thoroughly?
Only at startup.
Originally Posted By: typ901
If it's piece of mind then change it...did you keep the old filter?
Yes but I punched a hole in the bottom to drain out the oil inside. I will be cutting it and posting it on here tommorrow.
It was ticking on every startup. 30+ seconds on the first start post oil change, then about 2-3 seconds every start up after. Yes filter was prefilled and lubricated thoroughly.
Originally Posted By: JerryBob
If you remove the RP, I'd be curious to hear back if that resolved the problem.
UPDATE: So now I drove the vehicle approximately 30 miles and let it sit for about 5 hours. This time: No start up noise whatsoever. I will start it tommorow morning. If it has any ticking at all, it is getting pulled and another Pureone or Fram Ultra will be replacing it. I am very dissapointed in this oil filter so far. I expect more than this from a company like RP.
