This is concerning a 2006 F150 with the notorious 5.4 3 valve engine. The extended spark plug design is known to get stuck in the cylinder heads, and then a special tool kit is required to get the broken plugs out, because even the portion the socket grips breaks off from the rest of the plug. A friend of mine took his truck in to have the plugs done, knowing things could get real bad real quick if he tried it himself, at the dealer quoted him a minimum of $850, including up to 2 broken spark plugs, and an additional $200 for each additional broken spark plug after that.
4 figure bill for routine spark plug replacement? Even for a dealership, that's pretty rotten. I think Ferrari, up the street isn't running quite that steep.
I happen to have the Lisle tool set to remove the broken plugs, so I did it myself and saved him a small fortune.
Just what the heck is wrong with Ford anyway? I knew they were good at putting out diesel trucks with poorly engineered engines that needed a king's ransom worth of maintenance, repair, and modification to stay on the road, but gas trucks too? Sometimes I don't know how Ford comes up with these bright ideas.
I have had plenty of DOHC 4.6's from Ford that were known for tossing the whole spark plug, along with the threads, so I guess they decided for their second go at V8 engines, they would make an engine whose spark plugs would simply never come out at all.
