Originally Posted By: MNgopher
Personally, I wouldn't pull the studs. I sometimes wish I could actually use them here (illegal in MN). That being said, I've owned the W409's (unstudded) and liked them. Worked well in loose snow, deep snow, and slush. Predictable in hardpack/ice conditions.
The problem with removing the studs is there is no going back without getting another set of tires... I'd hate to find out it was a mistake to take them out...
Apparently OK for visitors, although I'm not sure about how you get there unless the car is transported on a flatbed. Apparently the only surrounding state where studs are legal is Iowa, although the others may have regulations for temporary visitors.
Quote:
https://www.revisor.mn.gov/statutes/?id=169.72
Subd. 4.
Occasional use of studded tires by nonresidents.
Notwithstanding the provisions of subdivision 1, a person, operating a motor vehicle properly licensed and registered in another state or province of a foreign country which authorizes the use of tires with metal studs or wire embedded tires on its highways, may operate the motor vehicle with tires having metal type studs or with tires having wire embedded therein on the highways of this state while occasionally within the state, and such use while occasionally within the state is not unlawful; provided that, the metal type studs shall not exceed 5/16 of an inch in diameter inclusive of the stud casing with an average protrusion beyond the tread surface of not more than 7/64 of an inch, and the number of studs in a tire shall not exceed two percent of the total net contact area. Use of a vehicle in this state on more than 30 days in any consecutive six-month period is not occasionally. Except, a person whose regular place of employment is within the state or who is a student at an educational institution located within the state, shall not operate a vehicle, regardless of its place of registration, upon any highway within the state if such vehicle is equipped with tires which would be unauthorized were the vehicle registered in this state.
Studs are legal six months out of the year ANYWHERE in California. It can be extended if the California Highway Patrol Commissioner decides to do it.
However, studs really only help with ice. They might actually reduce traction if it's dry or on well-plowed roads with only a dusting of snow.
