This is a sample from my first OCI on a recently acquired used 2002 Passat (150k miles) my daughter drives. The previous owner was pretty good about having the oil changed on schedule (VW specifies a 5,000 mile OCI), but he frequently used quickie lubes with whatever bulk dino oil was on hand. This oil was M1 5w-30, and he added an unspecified amount and type of make up oil over this interval. Previous owner estimated oil usage was 1 quart per 1,000 miles, which is how Blackstone assumed there were 5 quarts of make up oil added during this interval. My experience so far is no where near that (in almost 700 miles I have not seen the oil level change much at all). So I suspect the actual amount added was 1 or 2 quarts max.
There is light sludge and varnish visible in the oil fill hole, and that seemed consistent with the consumption problem reported by the previous owner. I asked Blackstone for guidance on gentle desludging, which led to the reply in the comments. I intend to run short OCIs with synthetic known for good detergency, and avoid additive flushes. I have M1 0w-40 in this car now, and I intend to use a VW 502.00 compliant oil going forward.
This car is in great shape for its age, was well maintained, has 4 wheel drive (4Motion), and is well rated for safety, so it's perfect for my daughter for now.
An autopsy of the filter used in this interval is here
