Originally Posted By: ThirdeYe
Originally Posted By: Danh
If the car has pronounced clutch chatter at launch, odds are very high the cutch has been contaminated with transmission oil because of leaking seals. This is often accompanied by a visible leak between the gearbox and engine when viewed from beneath. The solution is replacement of the offending seals with an improved version.
In addition, a number of software updates have been made, all of which smooth out the DCT's behavior.
Rental car companies are not likely to bring the car in for service as long as it moves. And ThirdeYe, remove the aeroshield on th bottom of the engine compartment and take a look for leaks. Even if none exist, have your father take it in to a competent Ford dealer for repair - these can be made to work well, and most do.
DanH, thanks I'll take a look. He took it to the dealership last year and they claimed it was "normal" for a dual clutch transmission to shudder the way his was.
It's not. The old TSB number was 14-0047, there is a new one, but I don't have the number handy. Mine is much improved with the new seals/clutch and programming, and overall it's much improved, but as the clutch has worn in, takeoff is starting to revert to slightly less desireable characteristics, and I'm considering taking it back in for the latest update. With the latest TSB in addition to updated software, is also the latest revision of the clutch pack (rev E, or F I think) Take it in and tell them it has severe clutch chatter. Any dealership service dept should be very familiar with this procedure.
