Hey guys,
I have an old Tercel that I have been unkind to over the years. I've used every oil imaginable in her, and some years I didn't bother. I believe I even used 20-50 in her one winter (-50 C, northern Alberta).
No block heater, started fine.
After pumping up the $26 Walmart 13" tires over pressure and changing to 5w30, she now gets nearly 48 mpg on the highway. I believe there was a mix of oils in her previously. Really quite thick and black, actually ... Anyway, the only other mods is a Harley Davidson muffler I picked up when the exhaust broke. $20 at a cycle salvage yard.
I've suddenly started to become very attached to her. And she responded so well to a lighter oil, I'm wondering if I could go 5w20. She burns no oil, and I was thinking of using a fl 400s oil filter (it's about the size of keg, apparently bolts right in, intended for a Ford F-150), increases the capacity from 3 litres to 3.5 litres.
Now, there appears to be some controversy over the 5w20 vs 5w30 thing. Nearest I can tell one school of thought says simply uses what the manufacturer suggests. 10w30 on the cap, but a recent oil chart from Toyota suggests 5w30. And there's always that 5w20 CAFE conspiracy thing ... But, see, I'm not opposed to tinkering a bit, I don't think the manufacturer would suggest my Harley pipe or over-inflated tires either and both have contributed to her stellar performance (less rolling resistance, small pipes, free flowing exhaust FTW!). And she just perked up so much when I put 5w30 in her, I'm kind of on the lighter-is-better bandwagon.
Besides, 5w30 sheers to 5w20 anyway, right?
Given her history and abuse, this may seem an odd obsession. But I've read a few posts on this forum, and you are all an odd lot. So I think I've come to the right place.
Best,
Speed Racer
(ps Driving will be a mix of
(pps Pennzoil PYB will be the dino oil I'll use. It's on sale right now in 5w20, 5w30, and 10w30 weights)
Best,
Speed Racer
