- Joined
- Dec 7, 2012
- Messages
- 3,558
OC tomorrow morning. Going to get up early and not waste the day!
AMSOIL Signature Series SM 0W-20 and a Fram Ultra XG7317 are going in. Plan for a 10-12k run, plan to get through the fall/winter and change in March. This AMSOIL i bought off of matrass months ago, finally using it!
So far I like the Fram Ultra filters a lot. No problems whatsoever. I can get them cheaper than the Honda A01 OEM with AAP discount codes, they filter a bit better and I can rest well running them longer. What's not to like?
Going out... a FU and 5k worth of Castrol GTX 5W-20 with some PYB 5W-20 as makeup oil... probably only 1/2 of a quart worth. I'm not worried if I use a half quart over 5k miles.
I know I under utilized this FU but it was pretty cheap with an Edge 0W-20 + filter sale.
Also, I changed my PS fluid today. Pumped 4 fresh quarts through the system then topped off and added a 4oz bottle of Lubegard PS protectant. I try to do that every 30-40k.
