Originally Posted By: jrustles
Prepare for some yapping, dude....
Originally Posted By: Drew99GT
Induced changes in pressure. You believe HAARP controls the weather.
strawman alert! "HAARP control the weather" is kind of a cartoonish take on the issue. Let's not say "control". Let's use more moderate terminology such as 'influence'.
HAARP the innocuously-named (lol'ing as I type this) "High-Frequency Active Auroral Research Program" is nothing but a scalable, very high powered radio transmitter. Put short, it's an array of discreetly-powered, finely-tunable super high powered magnetrons pointed at the sky. It is far from being the only array in current existence.
The tunable thing is critical because it allows an array of 90 degree vertical radio cannons to dynamically aim and focus in any direction. My skeletal understanding of the mode of action is that by altering the frequency phase slightly among the array, that they can intersect at some point a single-phase transmission at a predefined dynammic location (ie NOT directly above the array).
Anyway, it is (was) indeed a research project, but not for a new University course. It (and the hundreds of ionospheric heaters that have subsequently been built around the PLANET) are multi-mode WEAPONS. (oh that's crazy he said weapon what a nutter
Apart from the lame stuff, like ionospheric shaping for radio propagation and missile defense, IONOSPHERIC HEATERS have much more practical and insidious purposes.
To get off topic a bit, here's where the whole tin foil joke got started. It is WELL-KNOWN, RESEARCHED AND DOCUMENTED that human brains operate on frequencies. These frequencies correspond to certain activities and behaviours.
http://www.ncbi.nlm.nih.gov/pubmed/14995060
http://mentalhealthdaily.com/2014/04/15/...ha-theta-delta/
Brain waves affect INFLUENCE behavior (not control, control is a strong word), and brain waves are easily entrainable. Riots, pacification, unrest, hypnotic-like stupor are all easy influences to apply to masses of people. I have my suspicions about the times
when each frequency is used.
The 'tin foil' on ones head is allusive to a make-shift faraday cage to attenuate ELF frequencies from entraining ones brain wave frequency. It has presumably become forced as a point of ridicule (COINTEL) to discredit the brain wave entrainment concern, which again at present day,
is well documented. IMO people that immediately cry TIN FOIL have no idea what they're even joking about, which is sad, considering these same people are the most confident and first to tell you, with all certainty, that "everything is perfectly fine, nothing to see" as though that ironic premise itself, was not insane.
That's undoubtedly "just too crazy" for you, this isn't about brain waves so lets get into just the practical atmosheric uses:
The ionosphere is naturally plasmafied by the sun, but the sun's radiation is sinusoidal (generally, apart for coronal changes) and the energy is applied "directly" (as in direct current) not modulated to multiple resonant frequencies. BIG DIFFERENCE.
By strategically modulating a relatively small (compared to the sun) amount of energy that is tuned to a specific RESONANT frequency (in this case the resonant freq of the plasma of the ionosphere), one can induce HUGE effects (thanks Tesla), particularly if a small part is plasmified, this disparity can induce great movements at the IONOSPHERIC level, which can have dramatic effects to the atmospheric layers below. If conductive particles are SPRAYED, the energy can be liberated at the aerosol level, creating artificial energy systems, like maybe a ridiculously stupid shelf cloud or boiling "mammatus" clouds. I will not even touch the tectonic effects. (Again, thanks Tesla)
The layers of the atmo are like water in a lake. It's still and laminar unless a wake is induced.
Focused energy injection: If you point a microwave magnetron at a glass of water across the room, the glass would start to boil, and no one in the room would know why, and there would be no trail between the transmitter and the target.
Quote:
Tell me how??? You do realize it's been off for over a year, correct???
Let's use the word HAARP to identify any ionopsheric heater array, like people use Kleenex to identify any given facial tissue. Kleenex is not a monopoly. People caught on the usefulness of Kleenex, and many facial tissues now exist for that reason.
Quote:
I just showed you that jet fuel is extensively tested; they add no metallic elements. There's no compartmentalization with jet fuel testing as there are too many FBOs/airlines that privately operate jet aircraft using commercial fuel. For the conspiracy to be real, ALL of them would have to be in on it.
In regards to ONLY commercial jet fuel doping, your key word "metallic". No one said they had to be metallic. EDB is not metallic.
Put short, this is my own personal GUT on this issue, far beyond anything else "conspiracy nuts" might postulate. a
I know how much is known about the atmosphere, to the point that humans can put it on it's knees, poke and prod it into doing exactly what one wants. And it's not complicated. How can we tell what the weather will be in a week, to a tee, down to the hour any given system may roll in and precipitate? Because those who wanted to know, know far beyond anything we know in the civilian realm, about how to run the weather, globally.
So HAARP produces shelf clouds and mammatus.
Dude, I'm a skywarn weather spotter and avid storm chaser. Can you please explain to me first, the harm done by shelf clouds and mammatus clouds, and 2, how HAARP produces them? That is laughable.
Shelf clouds are produced along the gust fronts of thunderstorms from the rain cooled outflow winds falling, hitting the ground and then causing a rising/rolling motion of air ahead of a thunderstorm. Perfectly natural phenomenon. As is mammatus which is nothing more than bubbly sinking cloud formations in the anvil of supercellular convection. Natural, happens all the time in strong, organized thunderstorms. Mammatus and shelf clouds are not "artificial energy systems"; they are natural cloud formations that form all the time.
