Originally Posted By: clarkflower
After some wd 40 the shift has not locked up all day
Got a radio for 100. Freon worked on the ac.
Got smogged.
I just found that the third brake light in the rear window works.
Would it work if it was in the steering column?
Originally Posted By: ThirdeYe
We have the same shifter issue with our Grand Am. Usually if we just push the brake and the shifter button really hard we can get it to release after a while. I'd love to know if you figure it out.
I could have hooked you up with the old CD player from my Firebird had I known you needed one. Where did you use the WD40?
Got smogged.
