Industrial hand cleaners?
by KenO
07/26/16 11:58 PM
Shell Rotella T6 in a Altima 2.5
by Grambo
07/26/16 11:24 PM
"Creaking" Conti DWS's?
by Lolvoguy
07/26/16 10:52 PM
Check your car after it's been worked on
by Nick1994
07/26/16 10:15 PM
How are lg android devices now days?
by ram_man
07/26/16 09:42 PM
Dexos 5w30 with highest 100c Viscosity
by CapitalTruck
07/26/16 09:32 PM
How do you avoid being perceived as a rookie when
by motor_oil_madman
07/26/16 09:27 PM
Oil opinions after dumping FF
by JoelB
07/26/16 09:27 PM
Bulk loading a grease gun?
by buck91
07/26/16 08:59 PM
Sears Battery Pricing
by PeterGreen
07/26/16 08:29 PM
My 12am emergency strut spring repair on a Civic
by Colt45ws
07/26/16 08:19 PM
My upper sidewall pinehole leak fix
by Pokermatters
07/26/16 07:52 PM
snydercn, surfbum, Tmemz4, woollum86, Phil108
58612 Registered Users
27 registered (Charlie1935, ChristianReske, 182RG, Bottom_Feeder, CrazeeDad, 2 invisible), 843 Guests and 14 Spiders online.
58612 Members
66 Forums
252296 Topics
#3468612 - 08/29/14 04:27 PM Rough idle on cold start
Falcon_LS Offline
Loc: Kuwait
Weird issue with my Envoy (4.2L L6) the last two days. On cold starts first thing in the morning, the engine idles rough (like a single cylinder misfire) for about a minute then returns to normal. If you rev the engine whilst it idles rough, it revs smooth as glass. No codes are stored in the PCM.
Worth noting, same thing happened this evening after the truck was sat for 12 hours and I had no cruise control. Pulled over, killed the ignition and fired her back up again and I had my cruise control back. Possible throttle body issue? Thanks!
99 Explorer EB: GC 0W40/FL1A
00 Pajero: Aisin PAO/Ester 5W40/MD352626
01 Marquis: GC 0W40/FL820S
03 Expedition: M1 0W40/FL820S
05 Envoy: GC 0W40/M1206
#3468614 - 08/29/14 04:31 PM Re: Rough idle on cold start [Re: Falcon_LS]
Skid Offline
Loc: USA - Southern California
If I had to guess, water temp sensor.
#3468617 - 08/29/14 04:33 PM Re: Rough idle on cold start [Re: Falcon_LS]
Char Baby Offline
Loc: Western NY
Possibly the throttle body needs to be cleaned or the(if this engine has one), the Idle Air Control Valve(IACV).
Research will help you fine where the IACV is!
Cleaning the T-Body with the proper cleaner may also aid in this idle issue.
Also, check for vacuum leaks!
This is just a start. Others will chime in with more helpfull information.
CB
"Retired"
'80 Firebird FORMULA V8/4bbl-NEW
'06 Mazda 3i 2.0L-Pre Owned
'15 Nissan Altima 2.5 SV-CPO
Still looking for a car for my wife(new, used, CPO)
#3468623 - 08/29/14 04:40 PM Re: Rough idle on cold start [Re: Char Baby]
Bud_One Offline
Loc: Spring,Texas
+1
Co-worker of mine has a 2004 Trailblazer with the 4.2 and had the same issue but never went away warm or cold. Throttle body was caked full of black goo. Cleaned it up and it ran great.
16 Civic-M1EP 0w20,Fram XG7317
05 Chevy2500HD-Amsoil OE 5w30,Fram XG3675
03 Vibe-Chev Supr 10W30,Fram PH3600
97 Accord-Delo 400XLE 10W30,Mahle OC330
#3468626 - 08/29/14 04:47 PM Re: Rough idle on cold start [Re: Falcon_LS]
Falcon_LS Offline
Loc: Kuwait
Thanks for the input! The throttle body was cleaned roughly 3,000 miles ago and even then, barely needed any cleaning. It was almost spotless (engine's fed Euro V gas).
I monitor ECT constantly with my ScanGauge-II - at cold start ECT matches ambient temp and fluctuates between 190-195 F at operating temp - I guess that rules out the ECT sensor?
#3468660 - 08/29/14 05:31 PM Re: Rough idle on cold start [Re: Falcon_LS]
Whimsey Offline
Loc: The Garden State
This may sound dumb but were they only looking at the throttle body on the visible outside of the throttle plate. My 1996 Ford Contour which burns no oil in 8500-9000 mile Oci's was clean on the visible front of the throttle body. Behind the throttle plate had black build up. After I cleaned it, it idles much better. Does it smooth up after it warms up? Mine now runs fairly stable idle, it only idles rough for a few seconds while still warming up, it only happens on the first stop after starting up. I'm sure my IAC valve should be cleaned but it's a PIA to get to so I'll live with less than perfect idle, but acceptable idle from a 4 cyl. I had no codes.
Whimsey
#3468687 - 08/29/14 06:11 PM Re: Rough idle on cold start [Re: Falcon_LS]
Trav Offline
Loc: MA, Mittelfranken.de
Try unplugging that and see what happens. Start with the simple stuff.
#3468717 - 08/29/14 06:51 PM Re: Rough idle on cold start [Re: Falcon_LS]
Merkava_4 Offline
Loc: Clovis, CA
Ah..........but are you just looking at it from the air side? I think you'll find that the throttle body looks quite different on the engine side. The engine side is what regurgitates all the combustion byproducts and oily PCV fumes onto the throttle body.
#3468751 - 08/29/14 07:34 PM Re: Rough idle on cold start [Re: Bud_One]
01_celica_gt Offline
Loc: St. Louis, MO
+1
+1 just finished a 98 corolla with throttle body full of oil. Took off the throttle body and IACV, cleaned them both as they were both full of oil. Afterwards idle went from a constant 1400 to 750 rpm normal now. I did do an oil consumption fix, now I can barely hear the engine running and its revs REALLY smoothly.
Edited by 01_celica_gt (08/29/14 07:36 PM)
Red/Black 01 Celica GT 1ZZ-FED(Rebuilt @ 211/144) @ 211/145k
Red 02 Corolla S 1ZZ-FED(Rebuilt @ 140k) @ 141k
All Autos!
#3468762 - 08/29/14 07:48 PM Re: Rough idle on cold start [Re: Falcon_LS]
Kuato Offline
Loc: In transit...
How is your battery? If it's not in good shape it could cause a miss. I've had 2 different vehicles over the years that acted as yours does. Losing the cruise control was the tip off.
Your oil's condition is speculation until you get a UOA done.
2013 F150, 5.0 4x4, 52k Schaeffer 9000
#3468800 - 08/29/14 08:27 PM Re: Rough idle on cold start [Re: Falcon_LS]
toneydoc Offline
Loc: War Eagle
Have you checked for any corrosion at the distributor cap and coils and spark plug connections. Have had rough running and misfiring in the past due to corrosion and buildup at some of the connectors on wiring.
1994 Jeep 146k Castrol 0w40
2014 Camry 15k TGMO 0w20
2010 Sebring 40k Valvoline 5w30
2014 HD Ultra 18k Valv20w50
2012 Toyota Rav4 22k Mobil 1 0w30AFE
#3469019 - 08/30/14 06:39 AM Re: Rough idle on cold start [Re: toneydoc]
Falcon_LS Offline
Loc: Kuwait
Found the culprit - we've been having some extremely humid weather of late and there was moisture in the coil in cylinder 1. Not sure how it got in, given I've generously applied dialectic grease when I did the plugs 25,000 miles ago, but I took this opportunity to pull the plugs out for inspection and reapply DG to all coil boots after blowing them clean with a compressed air gun.
That being said, I always clean my throttle body off the vehicle. In this case, it's drive by wire so I don't want to be messing with the plate. Removing it and generously spraying it with throttle body cleaner or brake cleaner does the trick, but it's always been clean with the gas I'm using.
#3469050 - 08/30/14 07:50 AM Re: Rough idle on cold start [Re: Falcon_LS]
Char Baby Offline
Loc: Western NY
Well done!
Thanks for keeping us posted on the results!
smile
CB
"Retired"
